mpg problem,take 5
Old Jan 26, 2000 | 03:30 PM
tmcalavy's Avatar
tmcalavy
mpg problem,take 5
Well, installed new EGR valve and EVR solenoid and took care of my code 33. Truck is still slurpin' gas however. Where do I start in diagnosing a rich fuel mixture? I guessing checking fuel rail pressure to test fuel pressure regulator. Am I right? If not, someone please point me in right direction.
Old Jan 26, 2000 | 03:43 PM
RGAZ's Avatar
RGAZ
mpg problem,take 5
Check the manifold vacuum with a vacuum gauge. I would recommend buying one, you can diagnose a ton of things with a simple vacuum system.
Randy
88 F150 4X4 w/lift.
Old Jan 26, 2000 | 03:57 PM
tmcalavy's Avatar
tmcalavy
mpg problem,take 5
RGAZ,
I've checked manifold vacuum with pump/tester. It's good and solid until I increase rpms...vacuum drops off as rpms increase. But, exhaust systems and CAT are good...no restrictions. Does this indicate vacuum leak at gasket and could this cause rich fuel mixture? How do I find source of vacuum drop off?
Old Jan 26, 2000 | 04:08 PM
Rob400's Avatar
Rob400
mpg problem,take 5
