Dash Ground Problem
Old May 31, 2005 | 08:07 AM
MARKC4's Avatar
MARKC4
Dash Ground Problem
94' E350 w/ dual A/C. While running A/C: the higher I run the fans, the Oil and Temp guages climb in direct proportion. Found a large gound from wiring harness to body behind drivers kick panel, didn't cure the problem. Anyone know of any other places to check?
Old May 31, 2005 | 10:31 PM
Franklin2's Avatar
Franklin2
You may want to pull the instrument cluster and clean all it's connections. It's not a fun job though.
Old Jun 1, 2005 | 09:09 AM
MARKC4's Avatar
MARKC4
Been there done that too. Still no go.
Thanks
kountzecobra
Feb 22, 2016 08:38 AM
NativeDescent
Apr 26, 2015 08:28 AM
maxu13
1978 - 1996 Big Bronco
23
Aug 2, 2006 07:50 PM
tengel
Oct 11, 2004 02:10 PM
big block power
Aug 2, 2002 01:42 AM
