Rough Idle
Old May 30, 2005 | 08:12 PM
nmaranto's Avatar
nmaranto
Rough Idle
First, let me start by saying that I have gained a wealth of information from reading the old posts. I think the information I saw on the old posts in regards to slow starter when engine warm may have solved a problem that has plagued my truck for years.
My truck is a 77 Ranger XLT F150. 400 CID engine, C6 Auto. Trans is rebuilt, engine is a rebuilt engine and has about 80,000 on the engine. Suddenly started idling rough. Accelerated normally and performance at speed seems normal.
Replaced rotor, cap, plugs, and plug wires and saw an incremental improvment, but still rough. The rough idle seem to be intermittent. I'm thinking it is something with the ignition system. Distributor and ignition control box are original and have a total of about 300,000 on them
Anyone have any wisdom to share
Old May 30, 2005 | 09:12 PM
Matts72's Avatar
Matts72
You should try adjusting your idle set screws on the base of your carburetor. You should turn them all the way in, not tight, then back out. Starting at 1 1/2 turns try to start your truck, it should start easily. If not, turn them out 1/4 turn at a time.
Otherwise, you probably need to replace your needle and seat in the carburetor.
Old May 30, 2005 | 09:16 PM
savage066's Avatar
savage066
you might look for a vacuum leak...a suddenly rough idle could indicate a disconnected line...also, check and see if the carb is tight.
Old May 31, 2005 | 09:51 AM
beartracks's Avatar
beartracks
The EGR plate under the carb is famous for warping and burning through. Causes the idle to change/surge as it warms up. Also the EGR itself could be the cause.
excoelis
2009 - 2014 F150
Jul 8, 2014 07:01 PM
WhiteBeast-05-powers
Nov 9, 2013 12:47 PM
Stevequesen
Feb 23, 2010 08:35 AM
cawildi
Oct 15, 2007 07:59 AM
gumboluvr
Jul 31, 2006 10:19 AM
