MP3/CD Stereo Problems
Old May 30, 2005 | 06:29 PM
1524's Avatar
1524
Anyone familiar with the Mach 3 MP3 Stereo? It will play MP3 cd's perfectly but if you try to insert a regular CD, it acts like it is loading an MP3 disc and then automatically ejects the CD. Will this thing not play regular CD's? Is it just screwed up? Anything I can do?
Thanks.
Old May 31, 2005 | 10:39 AM
Traxxis's Avatar
Traxxis
Hmm... try the audio forum... does it give you an error code? It should play regular cd's just fine... but talk to those guys.
STan
Old May 31, 2005 | 08:19 PM
agoldberg03's Avatar
agoldberg03
Have you tried playing that same audio cd in a different cd player? Is it a store purchased audio cd or one that you copied on a pc? If you burned it yourself (but used audio files instead of mp3) there is some sort of disc "finishing" that some burners do not do that will make them unplayable in our Mach player. I had problems with the windows media player and had better luck with another. Try these and let us know...
Old Jun 2, 2005 | 08:03 PM
stenzler's Avatar
stenzler
Im thinking its just a bad chip in the headunit... i work for a car audio install place and we do get those every so often
Old Jun 2, 2005 | 09:21 PM
1524's Avatar
1524
I've tried several "store bought" cd's and no luck at all. MP3 cd's work great. What do I do about a bad chip in the headunit? Thanks.
Old Jun 2, 2005 | 11:43 PM
stenzler's Avatar
stenzler
basically what you need to do is try to send it back to the manufacture... it should have come with some sort of warranty... just give them a call, explain your problem, and then they will probably give you an address to send it off to.. hope this helps..
Mike
