Tach question
Old May 30, 2005 | 08:58 AM
Daplumma's Avatar
Daplumma
Tach question
I aquired a Sun super tach 2.It has 4 wires and of course no instructions.The colors are red black green and blue.Anyone have this tach or know where they connect?Thanx.
Joe
Old May 30, 2005 | 09:20 AM
hiball3985's Avatar
hiball3985
I believe the red goes to a hot+, black goes to coil-, green is ground and blue is for light
Old May 30, 2005 | 09:21 AM
truckfarmer's Avatar
truckfarmer
If I remember correctly, the red is 12 volts power, black is ground, blue is light, green goes to the coil. Good luck!
Old May 30, 2005 | 10:18 AM
hiball3985's Avatar
hiball3985
I think truckfarmer is right..sorry for the bad info, getting senile
Old May 30, 2005 | 10:33 AM
Daplumma's Avatar
Daplumma
Thanx guys I think you are correct.I'll let ya know when I install them.
Joe
Old May 30, 2005 | 12:04 PM
Putt's Avatar
Putt
That is how the Sun Super Tach in my parents Dodge is hooked up.
Old Jun 4, 2005 | 10:33 AM
Daplumma's Avatar
Daplumma
I'm installing it now.Does the coil wire goto the positive or negative side of the coil.I'm assuming + but you know what that will get ya.Thanx
Joe
Old Jun 4, 2005 | 10:36 AM
hiball3985's Avatar
hiball3985
should go to the negative side, the one that goes to the distributor
Old Jun 4, 2005 | 10:44 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
neg / -
Old Jun 4, 2005 | 01:28 PM
Daplumma's Avatar
Daplumma
Thanx.I'm just finishin the wiring.Now to hook it up.Glad I checked back.
Joe
Old Jun 4, 2005 | 03:39 PM
Daplumma's Avatar
Daplumma
I think my motor must be running backwards.When I rev it it pegs the tach backwards.Just kiddin...works like a champ ...thanx for the help.What rpm do you redline at?What rpm are ya running at 65?
Joe
Old Jun 4, 2005 | 03:42 PM
hiball3985's Avatar
hiball3985
red line depends on what motor you have and what mods, at 65 it could be any rpm depending on gearing and tire size
Old Jun 4, 2005 | 06:15 PM
Daplumma's Avatar
Daplumma
352, headers,dual 2.5 inch exhaust,pertronix,650 double pumper holly,and 4:10 limited slip gears thru a c-6 trans.seems a bit high strung at 75 mph or so.Haven't checked it on the tach yet.
Joe
Old Jun 5, 2005 | 06:48 AM
jowilker's Avatar
jowilker
Joe, Them 4:10 gears are hard on the ol FE. That thing outta leap off the line, and get 9 mpgs.
I have my tach red line set at 4000 rpms. I did have it a touch past that wednesday when I ran my ol boy up to 90 in second. My 3.00 rears help make that happen.
2050 at 55 mph.
John
Old Jun 5, 2005 | 07:09 PM
Daplumma's Avatar
Daplumma
Took it for ride today.Bout 3 grand at highway speed.Speedo is a bit off but I/m guessin 65 or so.She really does jump off of the line and gets 6 gallons to the mile or so it seems.Mostly use it to go to the dump and grocery runs on the weekend.
Joe
