Tries
Old Jan 22, 2000 | 01:10 AM
KC's Avatar
KC
Tries
Does anyone know if I can put 35X12.5X15 on 15X8 inch rims? I will be installing these tires on a 94 F150 2WD $" suspension lift, 2 Inch body lift, and 4:10 gears. Thanks in advance
Kevin
Old Jan 22, 2000 | 10:23 AM
PAUL_2's Avatar
PAUL_2
Tries
Kevin,
Ive got 31 10 50 / 15in on 8in rims , Ive had 32 11 50 on it . I am pretty sure you will have to go to 10 in rims ? Some of the others may know for sure , you might give a tire shop a call too and see what they think ?
Paul
Old Jan 22, 2000 | 06:01 PM
Trail_Rider's Avatar
Trail_Rider
Tries
I've run 31.00 x 11.00 x 15's on stock 7" rims so you should be able to run 12.50's on 8's. You're going to have serious sidewall bow so to get a flat tread pattern you're going to have to run lower tire pressure. I would do this by laying my driver's license on the ground and deflating the tire until I could no longer get the license to slide under the tread. It seems to me I ended up running 22 psi. The other problem I ran into is the rear inside lugs used to hit the frame when turning lock-to-lock, so just don't turn so tight. You asked if it could be done and the answer is YES. However, I still don't recomend it. You're better off going to 10" wheels.
Trail Rider
Old Jan 24, 2000 | 04:48 PM
rockcrawl's Avatar
rockcrawl
Tries
I've got 12.50s on 8" rims on my J**p with no broblems. A BFGoodrich dealer can look it up in the catalog(I used to have a copy of the page but I cant find it). I think the reccomended rim width for a 35 12.50 is 9-11 inches.
Old Feb 2, 2000 | 07:50 PM
BIGTUFF92's Avatar
BIGTUFF92
Tries
HEY KEVIN, I TRIED PUTTING A SET OF 36" COYOTE'S ON 15X8 INCH RIMS, WITH A 6 IN SUSP. LIFT ON A 92 4X4 AND THEY HIT THE BUMPER ON TURNS. IT SOUNDS LIKE YOURS WILL BE CLOSE. GOOD LUCK.
Old Feb 2, 2000 | 10:43 PM
KC's Avatar
KC
Tries
Thanks for the info. I think I'll just go with 33's.
Kevin
Old Feb 3, 2000 | 08:25 AM
Phillip Guidry's Avatar
Phillip Guidry
Tries
BigRed7.3l
Sep 17, 2013 07:40 PM
triton54
1997 - 2003 F150
Jul 3, 2006 10:55 PM
MALIBUBASS
2004 - 2008 F150
Nov 2, 2004 03:37 PM
kevinbegley84
Jan 17, 2003 12:52 AM
crandall
Apr 7, 2002 04:21 AM
