Check engine light
Old Feb 2, 2000 | 04:31 PM
FKester's Avatar
FKester
Check engine light
I installed a new cat. and dual exhausts on my 1996 F150 300 six. After a month the check engine light came on and I have been told that it is because of the new cat.
Any suggestions for resolving this. Would putting the o2 sensor before the cat. make a differenct.
Old Feb 2, 2000 | 10:57 PM
00stick's Avatar
00stick
Check engine light
Go buy a code scanner. For $30 it will tell you what to check. It could be a sensor or something went bad.
Old Feb 3, 2000 | 08:25 AM
Phillip Guidry's Avatar
Phillip Guidry
Check engine light
First, how many O2 sensors does your truck have and did you eliminate any when you did your exhaust upgrade.With you asking about putting the sensor in front of yhe cat tells me that your truck was originally equipped with two,an upstream & a downstream,but I could be wrong. Also, detail the original exhaust compared to the modified exhaust, such as having primary & secondary cats original & dual cats,dual exhaust now.
Phillip
Old Feb 3, 2000 | 08:34 AM
slikness's Avatar
slikness
Check engine light
