Lokar Kickdown for C6...really quick question
Old May 29, 2005 | 10:40 PM
53fatfndr's Avatar
53fatfndr
I don't have the original kickdown bracket on my tranny, just the threaded "shaft" that comes through the center of the actual shifting linkage ('71 C6). I'm assuming this threaded shaft is where the factory kickdown bracket is supposed to go??
My quetion is, do I need to go find a bracket in the junkyard for this, or does the lokar kickdown kit have the bracket in it already? I appreciate the feedback
Old May 30, 2005 | 12:51 AM
Steve_Uzi's Avatar
Steve_Uzi
I needed to use the Lokar kickdown cable when I installed the 460 in my Bronco as the Dinosaur arm wouldn't work.
The Lokar kit comes with a bracket to hold the cable down at the Tranny end, but not up at the Carb end, I had to fabricate a bracket out of 1/8" Aluminum 1/2"x2" L channel.
Old May 30, 2005 | 10:37 AM
53fatfndr's Avatar
53fatfndr
Alright, good deal. That's all I needed to know. Thank you Steve.
Old May 30, 2005 | 11:30 AM
hatemakings/n's Avatar
hatemakings/n
Lokar has a bracket for the carb end but you order it seperatly.
F-250 restorer
Jan 12, 2013 01:47 PM
CountryBumkin
Oct 25, 2012 04:30 AM
82f100460
Feb 24, 2012 03:16 PM
GeneStoner
May 19, 2004 08:18 PM
