rear ends
Old May 28, 2005 | 09:00 PM
mwkobe's Avatar
mwkobe
rear ends
wil the rear end from an 86 f-150 4x4 fit in an 89 150 2x4 with no major modes
wayne
Old May 28, 2005 | 09:04 PM
tex94F250's Avatar
tex94F250
Should do just fine. Make sure to measure the spacing on your spring perches just to make absolutely sure. The u-joints may vary slightly, depending on the mood at Ford.
Just joking, I'd check them thoroughly for similarity though.
Old May 28, 2005 | 09:35 PM
71 Sport Custom's Avatar
71 Sport Custom
Wayne, You probably won't have ABS anymore if the 86 doesn't have the sensor. I think the Ebrake cables may be different so you'll need to stick with the 86 cables. Good Luck
Old May 28, 2005 | 10:07 PM
phoneman91's Avatar
phoneman91
Is 1986 rear end a Ford 9 inch (no inspection plate) or is it a 8.8 inch Ford (inspection plate at rear)?
I have seen factory installed 9 inch and 8.8 inch rear ends on 1986 Ford F150s.
Old May 28, 2005 | 11:04 PM
mwkobe's Avatar
mwkobe
i believe its an 8.8
havent looked at it in a while
wayne
