Diesles and elevation
Old May 27, 2005 | 11:24 PM
KING's Avatar
KING
Diesels and elevation
I will be doing a trip to Colorado later this summer and some one told me that diesels do not like elevation too much.
How much of this is true?
The exact location I'm going to is Ouray.
Old May 28, 2005 | 12:13 AM
Fire Rooster's Avatar
Fire Rooster
The older diesels didn't. The new ones no problem, that is what you have a turbo for.
Old May 28, 2005 | 12:53 AM
arninetyes's Avatar
arninetyes
Yeah, no kidding. The old, non-turbo diesels would lose power and smoke brutally at high elevations.
Turbo diesels, no problem.
Old May 28, 2005 | 09:03 AM
bspeake's Avatar
bspeake
Exactly. This is the same principal used in turbocharged aircraft. The high MAP makes it seem like you are flying at sea level, so you can fly at 20,000+ feet with no problem.
Old May 30, 2005 | 05:50 PM
KING's Avatar
KING
Sounds like a winner.
Thanks for the replies.
Old May 30, 2005 | 08:24 PM
johnny8's Avatar
johnny8
pulled my 5ver, (10k lbs.), up some long grades coming home today... started off taking it easy on the girl...(60 mph or so in drive), but... the more she ran.. the better she ran... she got to the point where she was pulling some moderate grades and holding 72-74 mph in overdrive no less..! one other thing... egt's seemed to come down as she started pulling the hills better... anybody have any theories on why this might be so..?
Old May 30, 2005 | 10:55 PM
Kwikkordead's Avatar
Kwikkordead
Lotta boost=lots of air moving through the engine, cooling things off.
Old May 31, 2005 | 05:54 PM
johnny8's Avatar
johnny8
ahhhh. i wondered if that might be the case... but...if that's true then why wouldn't she run lower egt's running down a gear.... higher rpms and even more boost.. (22 instead of 16)...? i thought the less you "lug" your motor the lower your egt's are... just wondering kwik... is it possible that blowing the soot out of the stock exhaust helps to lower your egt's...?
Old May 31, 2005 | 07:31 PM
Kwikkordead
Hmmm, I'm kind of guessing here that higher RPM=more combustion events per minute, creating more heat that has to be carried off. Even with the greater air mass in the combustion chamber, it just can't keep up. I don't think that cranking the boost to 60psi at high RPM for even greater air maiss(just an arbitrary value for the sake of discussion) is the answer either, blown boots and head gaskets aside. You get into the realm of diminishing returns due to the turbo generating it's own heat from the compression and blowing it down the intake's throat.
Old May 31, 2005 | 07:44 PM
johnny8's Avatar
johnny8
that makes sense kwik... she took about a half hour of towing to heat eveything up and clear her pipes a couple of times, then she started to pull real well... in od, i would slowly step on the acelerator till she got up to 16 or 17 lbs of boost and running around 75 mph... and just hold the peddle in place... she would back down to 70 or so and loose a little boost... but... she would stay in od and pull the hill with the egt's 100 degrees or so less than when i was down a gear and running 62-65... that's what i REALLY love about gauges... they let you learn how your truck runs and you can adjust how you drive to how she likes to be driven..!
