Blowby
Old Feb 12, 2000 | 07:34 PM
81oval's Avatar
81oval
Blowby
I have a recently rebuilt 302 in my F150. It has about 15,000 miles on it. Today I noticed that the oil had a strong smell of gasoline to it. I dicovered this after I pulled the pvc valve while it was running, and got a lot of gasoline smelling vapor to it. I realize that I should do a compression check, but I had ford do this when it had about 4,000 miles on it. Is this abnormal? Also, I have a whistle comming frome the carb or intake. I have rebuilt the carb after the engine went in, and noticed at that time that the butterfly staft was a little loose and slightly bent. It usually runs really good, but today I got a sound comming from it that sounded like a bunch of large steel ***** rolling over a rough wood floor. Am I headed for somm trouble here? Mark.
Old Feb 13, 2000 | 07:50 AM
JoeB's Avatar
JoeB
Blowby
Old Feb 13, 2000 | 08:56 PM
81oval's Avatar
81oval
Blowby
Turned out to be a bad fuel pump. Changed it and the oil. Worked out good. Mark.
VintageBlueOval
Jun 2, 2025 05:18 AM
F357
Feb 22, 2015 03:08 AM
fixnair
May 30, 2013 06:22 AM
MonumentalFord
Nov 9, 2004 10:46 AM
ernie
Oct 4, 2000 11:55 PM
