Code Help!
Old May 26, 2005 | 07:15 PM
species's Avatar
species
Code Help!
1990 351W EFI.
Trouble starting, but once it starts it runs good. Pulled codes:
565 - Canister purge solenoid circuit fault
334 - EGR closed valve voltage high.
Anyone have any ideas how to fix? This has been driving me crazy for a while.
Thanks
Old May 27, 2005 | 10:09 PM
species's Avatar
species
Replaced the EGR sensor - that fixed the 334 code. Anyone have any idea where the canister purge solenoid is??? I assume it refers to the purge canister located on the passenger side fender well. There is no solenoid attached to this. WTF!
Any help out there?
Old May 28, 2005 | 12:56 AM
matt17's Avatar
matt17
follow the vacum from the canister goining to the intake,solenoid is usually spliced into that vacum line!i would not worry about the purge solenoid,it usually sets a code when you have a egr problen or other emission problems!
Old May 31, 2005 | 08:36 PM
species's Avatar
species
Well, I guess I found the problem - there isn't one there! there is a connection, but no solenoid.
Thanks for the info - I'm off to the parts store
Old May 31, 2005 | 09:59 PM
matt17's Avatar
matt17
hope that fixes the prob!
