Paint Choices
Old May 26, 2005 | 04:24 PM
CougarMark67XR7's Avatar
CougarMark67XR7
Paint Choices
I own a 95' F 350 that I purchased last fall. Can anyone tell me if the original paint is two stage base clear, or is it single stage enamel or eurethane?
Thanks, Mark
Old May 26, 2005 | 10:23 PM
phoneman71's Avatar
phoneman71
Check the manufacturers lable in the driver's door jam and look for a two letter paint code. Tell me what the code is and I may be able to tell you if it is two stage paint or not. Most metallic paints in the 1995 MY were clear coated--I believe.
Another way to determine if the paint is two stage is to wax it with cleaner wax and then note if there is color transfer to the polishing clothe. If there is color transfer--the paint is single stage. If there is no color transfer--the paint is two stage.
Old May 27, 2005 | 01:05 PM
GWall's Avatar
GWall
Unless it has been repainted somewhere along the way, your truck has a base coat/clear coat system.
Old May 27, 2005 | 08:41 PM
frederic's Avatar
frederic
95? If it's factory paint it's a clearcoat system.
And, if you take your paint code ("YY" is my truck's off-white paint code) to any body shop or an auto body supplier, they can match it with any kind of paint you want - laquer, enamel, acrylic enamel, or base/clear two stage paint.
teched
Apr 6, 2014 08:14 PM
bucks77ford
Paint & Bodywork
Nov 23, 2012 08:20 PM
restoringmy46
15
Jul 26, 2012 01:01 AM
alvald83
15
Jun 11, 2010 04:56 PM
IES
Paint & Bodywork
Dec 19, 2002 11:30 AM
