Anyone?
Old May 26, 2005 | 12:18 PM
Ranger88Den's Avatar
Ranger88Den
Anyone?
1988 Ranger, 2.9. A4LD w/floor shift. Does anyone know of an aftermarket shifter that would be a direct replacement for the stock unit. I am having problems with the shifter handle not engaging into Park or D1. Thanks in advance.
Old May 26, 2005 | 02:44 PM
oppy's Avatar
oppy
Well, I'm not sure how "direct" you mean, but I'm pretty sure the B&M Truck Megashifter will work - and so will many of the other aftermarket floor shifters.
Old May 26, 2005 | 05:19 PM
Help I M Stuck's Avatar
Help I M Stuck
Your Ranger have a lift on it? I have a 87 Bronco II and it did the same thing. After trying to readjust the shifter linkage i had no luck..so i cut a small piece out of the bottom of the plastic casing where the shifter handle rod hits..worked like a charm..just needed a little more travel space.
Old May 27, 2005 | 06:46 AM
Ranger88Den
Thanks for the reply oppy & Help I M Stuck.
