Tires
Old May 26, 2005 | 07:49 AM
IVXIV's Avatar
IVXIV
Tires
My Mazda B4000 4+4 calls for 265/75/15 tires Would it be ok to use 225/70/15,s on it.I dont carry any loads with it.
Old May 26, 2005 | 08:25 AM
GWIGG's Avatar
GWIGG
Shouldn't be a problem, but the tire will be smaller in width and outside to outside diameter.
Old May 26, 2005 | 11:14 AM
G2IC_Wraith's Avatar
G2IC_Wraith
I would advise against this. That tire is MUCH smaller than your OE. Why on Earth do you want to do this? Go to http://www.miata.net/garage/tirecalc.html to see a visual of size difference. You are going to have a tire that is more than 10% smaller circumference than OE. That will raise your RPM quite a bit, and your speedo will be off quite a bit too. IMO - not a good idea.
