No Start
Old May 25, 2005 | 01:44 PM
Quackhead94ranger's Avatar
Quackhead94ranger
No Start
aiight, my truck does not like to start lately im kind of confused as to the culprit tho. because at first i thought that it was the battery cable, but then i realized that if i use a screwdriver on the starter solenoid, it starts right up, so i bought a new starter solenoid and figured that was the problem, well i changed the solenoid and it started just fine, AT first, then 10 minutes later i get in my truck and turn the key and NOTHING. im very annoyed by this, is it possible that my new starter solenoid is bad? or could it have something to do w/my battery cable?
i just replaced my starter less then a month ago also. any ideas?
Old May 25, 2005 | 02:04 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Have you checked for a grounding problem? It it always a no crank when you have the problem?
Old May 25, 2005 | 04:28 PM
Quackhead94ranger
yes it is aloways a no crank kinda deal. but now the problem is worse, i cant even get it started at all. this is pissing me off. how could i blow aother starter? this is the 4 or 5th starter i've gone thru in a little over a year. why is this? what is going on????
Old May 25, 2005 | 04:45 PM
87 XLT's Avatar
87 XLT
Try this, pull the wire with the rubber boot off of the starter relay. Have someone turn the key to run & see if you have 12 volts on this wire.
Got wiring diagrams?????
Old May 26, 2005 | 07:45 AM
Quackhead94ranger
allright! i will do that, but what does it mean if it doesnt have 12 volts?
Old May 26, 2005 | 01:39 PM
CowboyBilly9Mile
It means you have a fault causing you to not get the 12V required to activate the starter solenoid; could be a bad switch for example.
Old May 26, 2005 | 04:37 PM
Quackhead94ranger
well my brother put a new battery cable in my truck for me, and when i turn the key all that it does is click. what does this mena?
and what kind of bad swithc???
Old May 26, 2005 | 05:24 PM
87 XLT's Avatar
87 XLT
The solenoid is part of the starter. Is that what you replaced? On Chevys they can be replaced. I did'nt think they could be replaced on Ford's.
The click you hear is the starter relay closing, so the circuit is good from the ignition switch to the relay. If it was the starter relay that you jumped earlier & started it, then the starter relay is bad.
Old May 26, 2005 | 07:49 PM
Quackhead94ranger
ford has a fender mounted starter solenoid as well as a solenoid on the starter were as chevy's ( i believe ) only have one solenoid, and that is the starter mounted one.
so you think that my starter solenoid is shot? i will look into it. thanks
Old May 27, 2005 | 01:46 AM
87 XLT's Avatar
87 XLT
Heres how your start circuit works. When you turn the key to start the starter relay closes & sends voltage to the starter solenoid. The starter solenoid shoves the starter gear into the flywheel & closes the contacts to complete the circuit back to the battery. From what you say it "sounds' like this part of the circuit is working.
So you might have a bad ground cable to the battery.
Try this simple little test, Add a jumper cable to the ground cable & see if it will start. If it does, replace the ground cable.
Got a starter circuit wiring diagram??????????????????
Old May 27, 2005 | 07:16 AM
pawpaw's Avatar
pawpaw
Could be a misbehavng intermittent Neutral Start switch, if it's a automatic tranny, or clutch switch if it's manual.
Old May 27, 2005 | 09:48 AM
Quackhead94ranger
allright! that's an awsoem idea and i will for sure try that when i get home from school! and no i dont have a starter circuit wiring diagram. were could i go about getting one?
and it is an automatic by the way
Last edited by Quackhead94ranger; May 27, 2005 at 09:49 AM. Reason: forgot something
Old May 27, 2005 | 01:05 PM
87 XLT's Avatar
87 XLT
For my 87 Ranger & 95 Taurus I have the Ford "electrical & vacuum troubleshooting manuals." Got them at helminc.com
These have the wiring diagrams for all the circuits in my vehicles.
VERY handy to have for figuring out electrical problems.
Sometimes all it takes to figure out an electrical problem is to look at a GOOD wiring diagram.
Old May 27, 2005 | 03:18 PM
Quackhead94ranger
yes i will look at that. but as of right now my truck starts. my brother put a new batter cable in and i bought a new starter solenoid and now it starts. but he thinks that if the new batter cable doesnt fix it that it could be the cable that goes to the starter solenoid to the battery.
i am kind of curious as to wondering if my keyless entry problem has anything to do w/ my truck going thru so many starters.
Old May 27, 2005 | 03:29 PM
Quackhead94ranger
well once again, started fine the first couple of time i try to start it. then i let it sit for a hour, go in, turn the key and nothing. but i can still start it with the solenoid.
this tells me ?
i dont know this tells me something but i just dont know what. gosh
