View Poll Results: Should I straight pipe her?
YES
41
74.55%
NO
25.45%
Voters: 55. You may not vote on this poll
Muffler
Old May 25, 2005 | 09:45 AM
so2315's Avatar
so2315
Muffler
Seems like an awful lot of people are removing thier mufflers. I heard one the other day and it didn't sound too bad, kinda throaty, and the turbo was really singing.
What is the flutter I have seen people talking about? Should I remove muffler or not?
Old May 25, 2005 | 09:51 AM
Max1775's Avatar
Max1775
Flutter is the noise made as the exhaust side of the turbo cuts through the exhaust gasses. I left my muffler in place (it's not stock but an aftermarket from Warpspeed), but running without one sounds pretty good to me.
Max
Old May 25, 2005 | 10:26 AM
bigdaddyTank's Avatar
bigdaddyTank
I have the Walker BTM, gives a nice rumble. I ran it with out the muffler and it was ok but I prefered the sound with the BTM.
Old May 25, 2005 | 10:44 AM
96ford4x4turbodiesel's Avatar
straight pipe is the only way to go...sound wise and hp wise...muffler gives too much backpressure
Old May 25, 2005 | 10:51 AM
444dieselrod's Avatar
444dieselrod
actually a stock muffler or an OBS should be a straight through design, with the lil glass pack cups on the inside, said to kill flutter and keep a nice tone, but i havent tried it yet, the stacks kill enough flutter.
the "cat" is what kills most of your sound, and is the most back pressure, on the OBS truck only.
Diesel Rod
Old May 25, 2005 | 11:48 AM
arninetyes's Avatar
arninetyes
On '99+ PSD 7.3, the muffler is a huge, reverse-flow design that contributes greatly to backpressure.
Old May 25, 2005 | 06:00 PM
18vtx00's Avatar
18vtx00
Smile
Diesel Rod
i got a stinger plus from banks, they told me to use the muffler or just to cut it out completely. just for sound benefits. but they said it out flows or at least flows the same as an aftermarket on the OBS. SD is very resrictive i am told. took the cat out and installed a 4" DP on buddies 04 SD 6.0. very responsive and has alot of turbo whisle...even @ idle.
Old May 25, 2005 | 07:13 PM
Kwikkordead's Avatar
Kwikkordead
Yes, it's internal pipe size is something like 2 inches only. I removed mine and installed a BTM.
Old May 25, 2005 | 11:55 PM
Skeeter2221's Avatar
Skeeter2221
I also was thinking of cutting off the muffler and going with the straigt pipe on my 01 PSD. I know most of the bennifits, but what are the neg.
Old May 26, 2005 | 12:03 AM
Kwikkordead
There are none of you get a Walker BTM. It's full 3.5" straight through muffler that looks like a fat bazooka. No reduction of inside diameter and you get a civilized sound that the better half will tolorate while riding in your truck.
Old May 26, 2005 | 08:05 AM
bigdaddyTank
What Kwik said, here is what it looks like
Walker BTM
Old May 26, 2005 | 10:17 AM
so2315's Avatar
so2315
What does the Walker BTM do? Does it make it as quiet as the stock muffler without the back pressure?
Old May 26, 2005 | 01:16 PM
bigdaddyTank
You can hear the turbo more and the flutter plus it gives a nice deeper tone, it is louder than the stock muffler, but not by much.
Old May 26, 2005 | 09:02 PM
18vtx00's Avatar
18vtx00
Smile
Walker BTM
so do they call this setup the paperboy???? LOL good pics though and pretty funny!!!
Old May 26, 2005 | 11:02 PM
QFD90's Avatar
QFD90
I vote for the Walker BTM also. I did it and love it. Sounds great, but not loud.
