5w20 versus 5w30, valve tapping
Pennzoil 5w30
Pennzoil 5w30
Anyone know if this will hurt the engine?? I ask because I purchased 3 cases of the Mobil 1 (full synth) 5w30 by mistake for my '05 Mustang - not realizing it called for the 5w20???
Thanks 390 - the "oil debate" is such a heated topic - you never know what to believe. I didn't think the 5w-30w would hurt it - good to know I can use it!
of South Georgia.
I was just washing one of my cars, and noticed that while it is only supposed to hit 106 today, it was just a tad warmer. 111. Of course it's cooler up near the airport where the area sensor is placed, 900 feet above in the junipers.
By the way, I use the 5-20 Motorcraft, and oddly, also have no problems with my truck.
If you bag a cam phaser, or score a camshaft, trust me, the dealer will do a check on your oil, weight, amount of contaminants, brand, etc.
Costs about 20-30 bucks to have that done, and if you are the loser, they get to keep the 500-1000 bucks the job can cost.
Locally they have a sign stating that they may have your oil analyzed (along with a bunch of other things, on claims). Not unusual, I’ve seen the same sign at Cadillac.
It’s just a response to the M-F law.
No I don't think 5-30 will hurt a dang thing, especially if you use a very good quality semi-synthetic.
It also won't help a dang thing.
No big thing. I just figure shoot the odds while it’s under warranty.
Chris
I have been forced to say that the makers of the trucks/cars have a little bit of a clue as to what they need. This was not my first choice of belief…
I changed the oil in my 7.4 to 20w-50 Castrol semi-synthetic at 8000 miles. I had been running the 10w-30 the dealer recommended since first oil change. I keep a detailed log of every mile that goes on the MH, every fill up, everything. A journal really.
Anyway, the mileage dropped precipitously, down from 11-10.8 running at 65+ loaded, without tow vehicle, to 9.8-10.2. No other changes. This is on five trips, scattered across the year, two oil changes.
So I went back to 10w-30 having noticed no improvement plus much higher oil pressure. 40 lbs at idle up to 50-55 at idle. After going back to 10w-30 my gas mileage surged back up to 10.7-11.1. With tow it had dropped to 9+, now it's back to 10+.
After years of the prevalence of the lighter oil, I am seeing cars locally with 250-300k on the factory rings/bearings/cams that have been run on the light weight oils.
I also always used the recommended weights in our fleet vehicles, Jeep Grand and a flock of Metro/Swift cars. Never had any oil problems.
The old Grand hit 262k never used a drop of oil. Lost exhaust manifolds, idler pulley, transmissions, etc. but never any internal engine problems with 10w-30 oil. We sold it, running great, just looking a little on the tired side.
It was thrashed every day of its life. That's in high altitude with high and low temperatures.
It made upwards of a thousand trips through the Cajon pass in five years. It got a little over 50k each year. I would like to say the oil was changed every 3k. But that would be wrong...
We didn't keep the Metros that long; they were run on mostly 10W-30, the last ones on 5w-30. Never had a valve cover off any of them.
Got one left in the family, it has 190k+ on it now, still doesn't use oil.
So as much as I was always loyal to thick oil, I think I am gonna go with the recommendations from the guys who build, and warranty the truck.
Chris
