Wheel bearings !
Old May 24, 2005 | 10:03 AM
RobertJohn's Avatar
RobertJohn
Question Wheel bearings !
I'm new in the form but not to the sight but I have a question about greasing trailer wheel bearings.
On my boat trailer I had those auto greasers with the spring and grease zert in the middle, just hook up to a grease gun and go..
Why would that work on my flat bed and Travel Trailer as well ??
A friend of mine and I were talking as this came up and this poped into my head, I'm sure it's been discussed but can I get one more reply ??
Thanks
Old May 24, 2005 | 10:26 AM
FrankLee's Avatar
FrankLee
You may be referring to Bearing Buddies. The problem with these is that the grease under pressure has nowhere to go. It can either seep through the inner seal or, if enough pressure exists, pop the seal out.
Seeping through the seal is harmless only if you do not have brakes. It just makes a mess on the inside of the tire rim.
If you have brakes, leaking grease can render them useless.
I have a small utility trailer with BB's and no brakes. I don't worry about the messy rims.
My travel trailer has a Dexter axle with EZ lube hubs. This design has the zerk fitting on the end of a hollow spindle. Grease is forced through the spindle, through the inner bearings, through the hub, through the outer bearings and back out the cap. No pressure is maintained anywhere in the system. It's a nice design.
Old May 24, 2005 | 10:43 AM
RobertJohn's Avatar
RobertJohn
Well thats nice to know I'd better check my TT to see if it's got those and hope it does. Your right, buddy bearing, I may do a manual greese on my flatbed then the buddy bearings but that might be over kill. Probably once a year manual greesing would be enough.
Thanks I'll go right now and check my TT..
Old May 24, 2005 | 12:39 PM
RobertJohn's Avatar
RobertJohn
Well, I checked and I do not have the E-Z Lube ... Mine is a Dexter axle...
Just a thought, can I add the E-Z Lube or would that require replacing way too much stuff and $$ ???
Also, a question off bearings.. Mine is a Layton Skyline TT.. In the door where the large electrical hook up is there is another reg. size plug ( male ) not but about 2 ft long.. Does anyone know what it is for ???
Thanks
Old Jun 14, 2005 | 09:06 PM
towdoc's Avatar
towdoc
both the EZ lube and the bearing buddies have the problem of blowing out the grease seal in the back of the hub, also neither of them cleans the water out of your boat trailers bearings.... you really need to pull the hub, clean and inspect the bearings clean out the grease and repack the bearings now and then. Pushing more grease into the hub doesn't clean out the fileing, water, etc thats there already.
Old Jun 14, 2005 | 10:17 PM
Steina's Avatar
Steina
CO River Rat
RobertJohn -
You'd have to change spindles to get the E-Z Lube system; probably easier/cheaper to replace the whole axle.
TowDoc -
The E-Z Lube spindles aren't pressurized, so they're not hard on grease seals. BTW, you can buy double-lip grease seals; I've had them on my trailer with an E-Z Lube axle for over 3 years, and have yet to see any grease on the inside of my wheels.
Steve
Old Jun 18, 2005 | 08:57 PM
pete dumbleton's Avatar
pete dumbleton
As a matter of fact, Dexter requires the double-lip plus retainer spring seals on the EZLube axles so the seals aren't pushed too hard when greasing (only time pressure is on them) -- BTW, Dexter sez to jack up the wheel and spin it slowly when pumping grease.
Bearing Buddies are great for boat trailers because the contraction caused by dunking a warm hub into cold water is less likely to suck in water (presuming the grease is still fluid enuf that the spring makes a difference). If I were using BBs on an axle, I would look up and get the double-lip seals next time I repacked (www.dexteraxle.com) -- On my relatively small #9 EZLube axle, it is a 10-60 seal vice the standard 10-9 seal.
Pete
