Trnasfer case noise
After having my transfer case oil replaced, I started noticing a one time knock while in 2 wheel drive. It only happens one time at around 18-20 mph. Won't hear again until I stop (or slow down to 2-3 mph) and take off again. Noise goes away when I switch to all wheel drive. Also, when switching to 4 low, the truck seems to "stall" or "slip" in first gear. Another words, I stop, switch to 4 low, give it gas and I hear the RPM going up but the truck is barely moving. Once the truck is out of 1st gear, it seems to move normal. Very confused..any help would be appreciated.
Thanks,
Matt.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
