Sponsored by: Real Truck
please help...
Old May 23, 2005 | 10:26 AM
94F150Shorty's Avatar
94F150Shorty
please help...
hey guys...
i just got a pair of tow mirrors for my 99 250 sd. i took the mirrors off and the wires are different colors. the dealer told me that i couldnt buy the connectors seperate from the mirrors. could some one please help me to match up the proper colors. the truck has black, red, blue and the new mirrors have purple and 2 other colors. please let me know and help would be great...thanks....
Old May 23, 2005 | 11:16 AM
mldmkr1960's Avatar
mldmkr1960
mirrors
Did one of these trucks have heated mirrors?
Old May 23, 2005 | 01:31 PM
94F150Shorty
no neither...i just need what colors should match up with the existing truck colors...
Old May 23, 2005 | 02:56 PM
Crash687's Avatar
Crash687
If you have 4 wires total on both the truck and the mirror, then use a volt and ohm meter to determine which 2 wires make up a pair. there should be two little motors that control the up/down and the right/left. each pair controls one axis, and the direction is controlled by polarity.
Old May 24, 2005 | 07:33 AM
94F150Shorty
but which colors from the new mirrors match the factory ones?
Old May 24, 2005 | 07:50 AM
FortyFords's Avatar
FortyFords
shorty,this from the 02 schematics with power mirrors
I have Red wire,Dark blue, Yellow.for the driver side
Violet, Dark Green and yellow for passenger.
Black is ground and the yellows are tied together
What are the exact colors you have on the new mirrors?
What crash was sayings is you need to determine which wires are hot when you move the mirror direction button.you can do it 12v test lamp.place the ground for the test lamp on the black ground wire in you old connector and move the the selector button to the mirror you want to move and probe the connector till the light lights up.
If someone here has a schematic for a 99 it would help! then just plug an play
Rich
Old May 24, 2005 | 09:09 AM
94F150Shorty
thanks for the reply...i didnt open both boxes of the mirrors...i thought i got out the drivers side and the colors were purple yellow and green, but maybe i just open the passenger side by mistake. the new mirrors have a round plug on them...the tech at the place i bought them from said they are specifically for my truck. but people on here are saying i need a square plug. thats why i was going to splice them in. where can i find the plug to plug the mirrors in. is it behind the door panel, or else where...thanks alot...
Old May 24, 2005 | 09:17 AM
FortyFords's Avatar
FortyFords
If I remeber you don't need to remove the door panel.But must pop out the switch panel.remove the black cover over the mirror bolts.then pop the sw panel out.
So your truck had power mirrors just not trailer tow power mirrors correct!
The plug should be in there.Its been awhile since I look at this! going from memory.
Rich
Old May 24, 2005 | 10:59 AM
94F150Shorty
yeah i have power just not tow. when you say switch panel do you mean the power window/lock switch panel? thanks alot for the help...
Old May 26, 2005 | 07:17 AM
94F150Shorty
thanks for all the help guys....the mirrors just plugged right in. i got mirrors with a round plug. if anyone is interested i got them from carpartswholesale.com. thanks alot....
mblaksley
Jun 9, 2014 10:17 PM
chspyder
Jun 25, 2011 11:37 PM
bigriz
Jan 31, 2007 06:45 AM
