No Spark at Coil
Old May 22, 2005 | 08:46 PM
Enterprizer's Avatar
Enterprizer
Unhappy No Spark at Coil
I have a 1978 ford F150 with a 351m. Its going to be a project truck.
Started it about a month ago no problem and when I went to start it the other day no go. There is no spark at the coil. Is it possible the ignition module died just sitting there.
Last edited by Mil1ion; May 22, 2005 at 10:42 PM. Reason: Split thread for own topic
Old May 22, 2005 | 11:08 PM
thesprocket26's Avatar
thesprocket26
Buy a new coil or use a known good coil to see if that is the problem. One wire should be hot(12v positive) and the other goes to your distributor.
Old May 22, 2005 | 11:28 PM
Mil1ion's Avatar
Mil1ion
Yes, the ignition coil can just die anytime,anywhere.
Do you have a multi-meter ?
You need to check the primary circuit & do a coil resistance test before you go buying parts though
Old May 23, 2005 | 12:59 PM
quehele's Avatar
quehele
Probably your module...
If you have no power to your coil you probably have a failed module. A defective coil will still show power to the terminals.
Hope this helps.
Old May 23, 2005 | 05:31 PM
'77fordtony's Avatar
'77fordtony
can i clarify something? you might have said this but maybe im missing it. is there no power in the wire going TO the coil or is there no power coming out of the coil. if theres power getting to the coil but not after the coil, its definately the coil but if its not getting to the coil it most likely is the module but before you go out and buy a new module, check if there is power going to the ignition module. just use a test lignt, and remember to make sure the key is turned to the on position. now if there is no power going TO the module even, it could be your ignition switch or maybe (someone correct me if im wrong) there is a fuse for the ignition but not sure.
Old May 23, 2005 | 08:28 PM
Mil1ion's Avatar
Mil1ion
No fuse, but a fusible link.
Pink wire coming out of the Ignition switch.
Old May 26, 2005 | 11:49 AM
Enterprizer
Yes I've tried a different coil. There is power at the coil and power going to the module out of the firewall but still have no spark on the coil wire
Old May 26, 2005 | 11:58 AM
Mil1ion's Avatar
Mil1ion
Coil wire ?
which one ?
+ terminal
- terminal
or
High tension lead to center of distributor ?
Please be more specific.
Old May 26, 2005 | 12:01 PM
Spaznaut's Avatar
Spaznaut
Could be your pick-up on the distributor. It won't trigger the coil to send a spark.
Old May 26, 2005 | 12:04 PM
quehele's Avatar
quehele
Bad coil wire?
Pull your coil wire -- get a piece of solid INSULATED wire (#12 from a piece of Romex will do) -- bend the end of the wire into a loop so it fits tight in the neck of the coil -- place the other end by a ground and turn the engine over. If you have spark you have a bad coil wire.
Hope this helps.
Old May 27, 2005 | 02:03 PM
Enterprizer
Would like to thank everyone for all suggestions. Got another ignition module plugged it in and away she went
Thanks again for all the suggestions
Enterprizer
