Vacuum Gauge
Old Feb 25, 2000 | 08:55 PM
AWOL's Avatar
AWOL
Vacuum Gauge
I've read several post that suggest a vacuum gauge to assist in adjusting a carb. I think I'll let you convince me, if someone can tell me where to get one of reasonable quality. Does Advance Auto or Auto Zone sell a decent one? How much does one cost?
AWOL
Old Feb 27, 2000 | 01:38 AM
Superdave's Avatar
Superdave
Vacuum Gauge
Either place should have a good one. Or NAPA. I really don't know about a specific brand. Just look at them and look at their visual quality. I don't remember what I paid for mine as I've had it 20 years or so. This will be a good addition to your tool box! Many uses. Yes they take the guess work out of adjusting a carb!!
Old Feb 27, 2000 | 08:48 AM
rocky50's Avatar
rocky50
Vacuum Gauge
Sure hope this isn't a goofy question but how do you adjust a carb. with a vacuum gauge? I've been using my gauge to check for Vacuum leaks and how many lbs. I get at idle. Is there any thing else I can check with this?
Thanks,
Moe
85 F150 302HOcrate orig. 300/6
Old Feb 27, 2000 | 01:35 PM
jmac's Avatar
jmac
Vacuum Gauge
Old Feb 28, 2000 | 12:09 AM
Superdave's Avatar
Superdave
Vacuum Gauge
Hook the vacuum gauge to a source of full vacuum. Now find your air fuel mixture screw, or screws. There is one on a 1 bbl carb, 2 on a 2 and 4 bbl carb. They will be at the base of the carb. With the engine running and warmed up, turn the screws out one at a time slowly. 1/8 to no more than 1/4 turn at a time. Watch the gauge to see if the vacuum increases. If it does, keep turning it till the vacuum stops increasing. Then turn the screw back in a 1/4 turn. Then stop and go to the other screw and do the same. You can use a vacuum gauge to check for bad valve guides. Timing problems. Vacuum leaks. General condition of the motor.
AWOL
Nov 28, 2002 06:09 AM
AWOL
Jul 28, 2002 12:02 PM
AWOL
1997 - 2003 F150
Sep 27, 2001 09:13 PM
AWOL
Feb 8, 2000 08:01 PM
