Bronco II Ford Bronco II
Engine temp / heater
Old May 21, 2005 | 09:11 PM
RomerB2's Avatar
RomerB2
I have a question.. when I was driving down the highway the other day my temp guage started to go up, so I decided that I'd take the heat and turn on the heater with the windows rolled down at full blast to see if I could get rid of the heat.. when I did this, my temp guage went all the way to the red.. what caused this? I thought it would cool down my engine, or did it?
Old May 23, 2005 | 02:42 PM
87 XLT's Avatar
87 XLT
If it's not low on coolant, i'd give the cooling system a good flush swap the T-stat and see how it does.
Old May 25, 2005 | 01:14 AM
goalscorer2's Avatar
goalscorer2
you might also be intereste in checking out the water pump .. i had the same problem when i was in stop and go traffic it would seem like it was going all the way up to top of norm and turned out thermo was a 190 and the water pump wasnt working at full efficiency
Old May 25, 2005 | 01:22 AM
trucku's Avatar
trucku
https://www.ford-trucks.com/forums/s...d.php?t=374605
Similar problem..read this tread
philv
Jan 1, 2017 10:31 AM
drof46
Mar 31, 2009 08:12 PM
Voyager687
1983 - 2012 Ranger & B-Series
43
Jan 8, 2008 08:54 PM
learmoia
Dec 29, 2006 10:16 PM
brider
Nov 2, 2005 03:44 PM
