Bronco II Ford Bronco II
Engine tapping
Old May 22, 2005 | 03:48 AM
fergie's Avatar
fergie
Engine tapping
Engine in my 88 makes intermittant tapping noise, usually after running for a while at highway speeds. Pulled valve covers. Rocker arm assy on drivers side pretty much devoid of oil. No visible damage. I am thinking that this is source of tapping. Any idea what is causing this, and how it might be fixed? Any info is much appreciated.---Ferg
Old May 22, 2005 | 11:24 AM
goalscorer2's Avatar
goalscorer2
as far as i have been told the tapping is due to a ppor design in the oil channels that are to lubricate the up assemblies... the only fixes i have seen available are a free floating assembly that can be bought or made ... a good book to get if you are interested in fabricating your self is svuenn preutts book on how to modify 60 degree engines... a trick ihave usd to quiet down my liftes was pour oil in and then use some of the lucas stabalizer stuff in conjucntion and it seems to really quiet them down.. i also use a 20-50 oil weight
Old May 22, 2005 | 05:54 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
I have to agree unless you cracked the heads and damaged the cam bearing.
Old May 22, 2005 | 09:48 PM
Help I M Stuck's Avatar
Help I M Stuck
mine rattle too..so i substitute 1quart of oil for 1quart of Lucas..that is some good stuff! quiets everything right down like brand new.
Old May 23, 2005 | 05:13 PM
fergie's Avatar
fergie
Thanks to all who took the time to respond. Can't live with the tapping, so will try to swap engines. Here we go.
Thanks again, Ferg
El_Rodney
May 10, 2009 07:52 PM
pwrdbyjp
Aug 26, 2007 09:27 PM
jjgoodus106
New Member Introductions
May 2, 2007 11:25 PM
dlcslcman
Dec 1, 2002 09:44 PM
55forder
Apr 20, 2002 07:21 AM
