Sponsored by: Auxito
towing question
Old May 21, 2005 | 10:07 PM
deltacoolguy's Avatar
deltacoolguy
towing question
In about a month I'll be towing a 1999 Mazda FWD w/manual tranny half way across the country with my '02 F-150 4.6L. My towing package is rated at 5000 lbs. I have a couple questions.
First, for a trip that far would it be better to rent a tow dolly or a trailer? I'm wondering about ease of handling of such a long trip. I've done both locally, but neither for such a long distance.
Second, is there any reason I couldn't use the cruise control while towing, or would that not be a good idea?
Old May 22, 2005 | 12:10 AM
bigdaddyII's Avatar
bigdaddyII
I would rent a trailer on a trip that long, that should keep you within your rating. I also dont see why you couldnt use c/c as long as you are safe about it. Dont use it on curvy roads and in the rain, just stay out of overdrive.
Old May 23, 2005 | 03:38 PM
deltacoolguy
I'm glad you mentioned overdrive. That was the third item I wanted to ask about, but my mind went blank. So, I should turn o/d off completely, eh? Sorry if that seems so basic, but most of my towing experience is with older trucks where o/d wasn't even an option.
Old May 23, 2005 | 05:47 PM
LxMan1's Avatar
LxMan1
A trailer is much safer. Especially if you have to back up.
On flat ground you may get by with OD, but I would lock it out. It keeps the engine in the preferred powerband and my truck gets better mileage when loaded and OD locked out.
Old May 23, 2005 | 07:53 PM
peppermrj's Avatar
peppermrj
I'm with the trailer, especially if it comes with a surge brake. Can't ever have enough brakes when trailering. Cruise is ok. In OD it seems to "hunt" a bit. Can't seem to decide between 3rd and 4th. I'd stick with Od on the flats also. Have a safe one.
