Dynomax headers vs Hedman ???
Old May 21, 2005 | 11:59 AM
71 Muddbugg's Avatar
71 Muddbugg
Anyone ever used or is using 4x4 Dynomax headers? I was going to buy Hedman but am getting talked into Dynomax. I know Dynomax has good products, just want the scoop and pro/cons. Price not to enter equation.
I suppose it would be a matter of preference but you get what you pay for...
Old May 21, 2005 | 12:53 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well I dont know how they make Hedman today? But I have a 33 year old set of Hedman's on my Truck.No hole or Leaks!! Knock on wood!!
Russ
Old May 21, 2005 | 02:04 PM
mlf72f250's Avatar
mlf72f250
My DynoMax have been fine for a year -- maybe 4000 miles. PITA to install on my 2x4 F250. Had to bend my C6 shift arm (broke it and MIG-ed it back on) to make them fit.
I used the individual soft white paper (asbestos?) gaskets that came with the header kit from Summit.
Old May 21, 2005 | 02:43 PM
ford390gashog's Avatar
ford390gashog
i just installed a set of dynomax headers from summit they fit good and don't leak but the paint on them like any other header burns off
Old May 21, 2005 | 05:10 PM
stegmst's Avatar
stegmst
I run Sanderson mid length headers (ceramic coated). No problems with exhaust too close to front drive shaft or headers contacting the over size pan I run. Ceramic coating holds up great no rusting headers.
Old May 21, 2005 | 10:43 PM
meatybtz's Avatar
meatybtz
I bought some dynomaxes a few years ago from sumit, turned out they were bent outa shape, die or something was bad, eh got my money back but was p.o.ed. I switched to Hooker super comps and have been happy except that i had to notch the frame to fit them into my manual F-250 4x4. That and changing starters requires me to remove the motor mount pedistal and the headers, so...
