Block ID
Old May 21, 2005 | 03:11 AM
bshackelford711's Avatar
bshackelford711
Block ID
can someone help me find my block cast ID?
i have taken the motor apart. (measure the bore and stroke to be a 390)
i have cleaned this block all over and did not find a casting ID. Where all can i look for these numbers or clues to what year this block is
Old May 21, 2005 | 05:48 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Does the block have vertical ribs on both sides? If it does it may be a service replacement block and will have no casting number. I've also seen non ribbed blocks with no casting numbers also. Otherwise it should be on the right side of the block. Check the date code also. G.
Old May 21, 2005 | 09:33 AM
bshackelford711
i have got the date codes and all that. It has no ribs on the side. I have found some other number on the block.
the mold number in 36
on the back i have the number 33
in the block it has 54 where the lofters are
58 on front above the 352 number
Old May 21, 2005 | 03:16 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
It sounds like a standard production block then. Some went through with no casting numbers. I think they were mostly 390 blocks also. G.
Old May 23, 2005 | 01:13 AM
bshackelford711
i checked my 352 in my 56 f-100 to see where the number was on that. It was right there where i thought it was at raised on kind of a rectangle. Then i went over to my 390 and had the rectangle but no stamp..... then i stop and was like hmmmmm????
Old May 23, 2005 | 11:27 AM
Mike G's Avatar
Mike G
If there are 2 engine mount bolt holes, it's a pre-65 block, if there are 4 mount bolt holes, it's later. Can I ask what the significance would be for you to determine the year of the block?
--Mike
Old May 23, 2005 | 11:30 AM
bshackelford711
2 bolt holes
none really i would just like to know.
Old May 23, 2005 | 12:46 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Well the date code tells you the year/month/date of the casting. With no casting number that's about the most you can tell. The heads, crank, rods etc.. will all have there respective numbers and should be around the same timeframe. The timing cover will have a casting number and a circle of dots with a number inside. That's the date code for the cover. Even down to the rocker assy's you can tell what everything is for the most part by the numbers. I'd use this as a gauge to support if the engine is all original to the car. As I mentioned it's quite common to find production blocks without casting numbers. Maybe the "number guy" at the foundry was out sick that day LOL. Just kidding....What heads, crank and rods do you have??? G.
Old May 23, 2005 | 02:33 PM
bshackelford711
i am at work now but i know the heads were c8 not sure which ones right off but i think they were c8ae
i will post the right info when i get home
