Sponsored by: Auxito
Wiring Problem
Old May 20, 2005 | 05:55 PM
smits03's Avatar
smits03
Wiring Problem
I have a 99 f-150 and i'm trying to modify the foglights so that i can have them on without the headlights being on, but i can't figure out witch wire i have to splice into in order to get power in to the foglights. I know that it has been done on a 2000 lighting and was told that it can be done on a 99. The info on the 2000 says the white/black wire but that wire is the indicator light power and has nothing to do with the foglights power. Any help would be appreciated. Thanks in advance.
Old May 20, 2005 | 08:40 PM
mrwhitefolx's Avatar
mrwhitefolx
If you have a Haynes manual, it might be easier for you to look at it yourself to figure this out. According to mine, it shows two white/black wires coming off the foglight switch, one goes to the fog lamp relay, and the other goes to the fuse panel (fuse #27) the other post off the switch has a yellow wire that also goes to the fog lamp relay. The only tricky part should be figuring out which of the 2 white/black wires goes where. Hope that helps some.
