Sponsored by: Real Truck
bad speed sensors
Old May 20, 2005 | 05:29 PM
scf100's Avatar
scf100
bad speed sensors
I have a 1999 f-350 bought used a year and a half ago with the small gas engine, had 70,000 miles on it. The check engine light has come on and the speed sensor was detected bad 3 times and replaced in the last year! Is there a prob with this part or? Its an auto trans too...thanks Stuart
Old May 20, 2005 | 08:08 PM
high ho silver's Avatar
high ho silver
Hey, good to here from another Ga. resident. Anyway, did you notice any metal particles on the sensor when removed. You may need to drain and replace the rearend fluid. Any metal in the fluid may cause it to act up.
Old May 20, 2005 | 08:47 PM
99f350sd's Avatar
99f350sd
I agree. The fact that you had 3 goes bad means most likely something else is up..
Old May 21, 2005 | 01:47 AM
chipndale63's Avatar
chipndale63
Are you sure its the senser? If you have 4 wheel anti-lock brakes you could very well need a updated anti-lock brake module controler, Thats what fixed my '01 along with the speed control surge at 70mph
Old May 21, 2005 | 06:17 AM
scf100's Avatar
scf100
speed sensor
I will have to check to see if it has anti lock...the computer code sez speed sensor each time the check engine light comes on....
stuart9534
Vehicles for Sale
Nov 5, 2013 12:55 PM
T-Bird Stu
Apr 29, 2013 10:27 PM
scf100
Mar 8, 2012 01:37 PM
born.to.ride
Jul 10, 2004 03:49 PM
