winclevturbo
Old May 19, 2005 | 05:47 PM
roofman73's Avatar
roofman73
winclevturbo
been gathering parts for a twin turbo on my 302 and now I'm looking for heads.what do ya'll think about a set of 2bbl cleveland heads on the 302 with a 650dbl pumper and twins.this is in a 78 250 4x4.I haven't selected a cam yet.
Old May 20, 2005 | 01:45 AM
bootie's Avatar
bootie
welcome to my world - my little 302w has clevo heads on it and mustang injection - feed by twin t28 turbos courtesy of rb25det Nissan Skyline
Old May 20, 2005 | 07:40 PM
roofman73's Avatar
roofman73
tell me more.lol
how's it run?what cam?what kinda compression?I can go on for days.
Old May 20, 2005 | 09:02 PM
bootie's Avatar
bootie
no compression at moment- prob end up with 8 - 8.5 - prob gonna run 2 head gaskets 2 keep it down - it's in pieces once again - waiting for parts - minimum of a month delay to get stuff to nz from the states waiting on forged pistons and rods - but am having second thoughts as to whether theblock is gonna hang in - debating buying a new block - probably won't till it cracks - cam is a crower item 15929 Turbomaster - also waiting for it to arrive - am in the process of fabing upsome new exhaust manifolds - estimating an easy 500 ponies at the crank
Old May 20, 2005 | 09:48 PM
roofman73's Avatar
roofman73
oh yeah that's what i'm talking about.ever since I got this clevor manifold from a swap meet I've been wanting to build a 302 with the heads and seeing as to how I've been putting this twin turbo together I figured what the hell.
good to hear someone else is doing it.I really won't be seeing high rpm with this motor in my 4x4.that's why I was wondering about the heads.
good luck on the project and I hope it meets you expectations.
Old May 20, 2005 | 10:28 PM
bootie's Avatar
bootie
ideally i want the 3v heads from Chiheads.com but 3500 aus is a big dump for me as we've just brought another house -
Old May 20, 2005 | 10:47 PM
roofman73's Avatar
roofman73
checked out that site...nice I wouldn't mind a set either.
Old Jul 9, 2005 | 08:46 AM
mooktank's Avatar
mooktank
2 head gaskets is probably a bad idea. I'd imagine it'd be easy to blow two out.
Old Jul 9, 2005 | 09:32 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
You are right, it is easier to blow 2.
If you can get sufficient clamping pressure then you should be ok.
Old Jul 9, 2005 | 10:03 AM
Wekiwa's Avatar
Wekiwa
Sounds like a great little toy!
Just MPO but the 2b heads could restrict total flow. You could also work the heads to help flow and increase combustion chamber volume too but I would never use more than one head gasket. Just too many ways to blow it out with boost. Since your using a twin setup total air volume can be huge with relativley low pressure and hence the need to ensure a good seal.
If I can find the spec card I'll post the spces. We used an Isky cam on a 302 with great results
Good luck with this project and let us know when its "alive".
Wekiwa
