1978 - 1996 Big Bronco
Code 634?
Old May 19, 2005 | 08:42 AM
masseysbronco's Avatar
masseysbronco
Question Code 634?
Ok i got a 93 351 e40d, and i just got a code reader. I first did the KOEO test, and got a 111 pass code. Then the code reader automaticaly goes into the CM test, and i got a 634 manual shift lever sensor voltage high/low than expected, or A/C on error. I have an automatic tranny and PB T-case,so what manual lever is it talking about? Oh and the A/C was OFF when i ran the test. After all that i ran the KOEO test and passed that one with 111.
Old May 19, 2005 | 09:53 AM
greystreak92's Avatar
greystreak92
The MLPS tells the PCM which gear is selected in the E4OD transmission. Its part of the shift linkage assembly on the tranny. If the linkage is loose it can sometimes trigger this code if the truck isn't all the way in gear. Have you ever had to push the gear shift stalk up or down to "convince" the truck it was in PARK well enough to start? This is the most likely and most common problem but the MLPS is known for just going south on ocassion.
Old May 19, 2005 | 01:45 PM
masseysbronco
Question
no my gear shift is accurate,so i guess i need to replace the mlps. What does mlps stand for? how expensive?
Old May 20, 2005 | 01:23 AM
greystreak92
Not certain on the pricetag but MLPS is Manual Lever Position Sensor.
Old May 20, 2005 | 07:00 AM
Streetgang's Avatar
Streetgang
I also have a 93, and I also have had the 634 pop up recently. I check for any codes every oil change, and last time I got a 634 in CM. I had no CEL, or any symptoms at all like hard starting or a hard time finding P so I can start, in fact no problem with the gear shifter at all. Both the KOEO and KOER tests came back 111, and since there were no outward symptoms of the MLPS failure, I went ahead and cleared the 634 out of the CM.......drove around a day or so and rechecked for it.........it did not come back, so I figure it was a anomaly and should be fine for some time yet.
You may also get lucky and have it not come back.......but that said I can tell you it is not uncommon for the MLPS to fail. It is a easy R & R, and the part should cost less than $50.
Here is one, but www.rockauto.com calls "it a Neutral safety switch", and lists the price for a unit equiped with a E4OD at $34
https://www.rockauto.com/applet3.html
Old May 20, 2005 | 08:39 AM
masseysbronco
Smile
Ok guys thanks! i think i'l try that out and see if it works.
subford
Oct 18, 2015 10:20 AM
ol_red92
Feb 23, 2015 09:23 PM
92 Red F150
Mar 10, 2010 10:17 PM
dahr85
Nov 3, 2009 06:51 PM
Ahrimanes2
1983 - 2012 Ranger & B-Series
Mar 1, 2005 09:09 AM
