Rusty frame question
Thanks
Lr
Essentially I took the bed off, dropped the tanks, removed fuel lines and such, did a reasonably quick driveway sandblasting job to remove all the loose rust. There was a couple of spots that wouldn't sandblast off, so I picked at them with a screwdriver, then continued to sandblast. I left surface rust that wasn't flaky, and rather tight, as per the instructions on the sealant/primer that I utilized - a product called "Ospho". What ospho does is convert iron oxide (rust) to iron phosphate, chemically, which once dry you can paint over directly, as iron phosphate is considered a primer. OR you can do what I did and just slather on three coats of ospho to seal it up. I didn't bother painting the frame since I never see it
POR15 is another good product to use for this... it's thicker but because it's thicker, you can't "dribble" it between rivited crossmembers and frame rails - POR15 will seal the edges, which is fine until your frame flexes, which they all do. This is why I like the "Ospho" product. It's cheap too, $10 a quart. $20 was all I needed to coat the frame end to end, the outside of both gas tanks, the bumper supports in the back, and the bottom of the bed, and I still have some left over. Goes on with a paintbrush.
If you have holes, that requires a different type of repair usually involved welding patches over things once the frame is cleaned down to the bare metal (with a real sandblaster), or replacement of sections depending if they are still available.
According to my local Ford dealer, the frame and crossmembers of the 87-96 pickups are no longer available - these parts were discontinued last year.
