General Automotive Discussion
determining chevy axle ratio
Old May 18, 2005 | 10:29 AM
Frost13's Avatar
Frost13
the rear end in my dads 89 chevy just went out and we found another truck that we could get an axle from. it's a 97 chevy.
is there any way to determine the rear axle ratio besides jacking up the truck and counting the spins of the tires vs. the driveshaft? i got the VIN number off both trucks and looked for a way decode it on the internet, but I never found one that could tell me the axle ratio.
Old May 18, 2005 | 01:16 PM
AlfredB1979's Avatar
AlfredB1979
Google!
http://gm-trucks.com/RPO_1998
"chevrolet truck rear axle codes" got me what you wanted.
Welcome.
Old May 18, 2005 | 03:05 PM
Frost13's Avatar
Frost13
http://gm-trucks.com/RPO_1998.shtml
is this what you meant to post?
since the oldest codes they have is 98, will it work for both the 97 and 89?
what would you use these for, the VIN number?
Old May 18, 2005 | 10:11 PM
00BlueOvalRanger's Avatar
00BlueOvalRanger
Look in the glovebox for a 'sticker' with the different codes on it. The 'sticker' is usually on the glovebox door. This is/are the build code(s).
Old May 19, 2005 | 09:00 AM
5_labsownus's Avatar
5_labsownus
If no one has been in to the rear end before there should be a small tag on one of the bolts that hold the cover on. this tag will be about 1 inch long and ti will have the ratio.
As for the glove box tag I hope your has the code and ratio on it. My Chev.. only has a tag that has about 50, 6 digit numbers and the dealer can't tell me what they are!
If the truck can't be driven you can pull the cover off the rear end and look for the part number stamped on the ring gear. It will be on the out side in view when the carrier is turned. You can look up the GM number or in front of that number will be 2 two digit numbers like (42 11) If you divide this out it come to 3.818... or 3.83. In the case of a friends truck (I think it was 32 11) or 2.909 or 2.93.
Old May 19, 2005 | 10:11 AM
Frost13's Avatar
Frost13
no, both are missing the tags. we had already knew about it and checked it.
we found where the RPO codes were yesterday before i read your post. thanks for all the info.
Old May 19, 2005 | 12:35 PM
polarbear's Avatar
polarbear
The RPO codes in the glove box should be three digit, alpha-numeric. All axle codes start with the letter "G."" Paint codes start with numbers, two digits followed by a U or a L. Trim codes are also numeric, followed by a letter.
G80- Locking Diff
most common truck codes:
GU6-3.42
GT4-3.73
GT5- 4.10
Old May 19, 2005 | 02:50 PM
Silver Streak's Avatar
Silver Streak
GM used to have separate stickers that told you what the options were in plain English. My 86 GMC had a sticker in the glove box that said "2.73 non-locking axle".
Old May 20, 2005 | 10:34 AM
Frost13's Avatar
Frost13
Originally Posted by polarbear
G80- Locking Diff
thanks. i was wondering about that. both trucks have it.
the 97 is a 3.42. don't know the 89's yet. gotta get all the codes.
Old May 23, 2005 | 10:31 AM
Frost13's Avatar
Frost13
they both have 3.42's. will the axle from the 97 work in the 89?
Old May 23, 2005 | 01:34 PM
polarbear's Avatar
polarbear
Frost13 they both have 3.42's. will the axle from the 97 work in the 89?
Yep- they should.
