No offense meant, but why would you want to swap in a lower rated axel?
Any way, the only hypothetical way to do it would be a mechanical setup, you definately wouldn't be able to go with the electrical setup that GM uses as it would be totally incompatible with the Ford computer.
If you went with a mechanical set up, it could be very dangerous as the parts wore out.
