General Automotive Discussion
Need help on Freestar
Old May 17, 2005 | 09:12 PM
Kenny Bonnell's Avatar
Kenny Bonnell
I install mobility products in vehicles for a living, and have a problem with a 2005 Freestar that I am hoping one of you Ford mechanics can maybe help me with. I installed a Turney seat in the front passanger area, which means I had to remove the OEM seat and install the aftermarket seat. Now for the problem, the manufacture sends a resister kit to put in place of the airbag switch and the weight sensor in the seat. I now have the airbag icon flashing first 9 times followed with 10 flashes. This continues to alternate between 9 and 10 flashes.The local Ford garage won't help me out with the code unless I bring it in. Anyone know what these flash codes mean?? I feel that the resisters are the wrong value, but the manufacturer says they are correct. I just thought I might try here before I pay the Ford garage to tell me. Thanks in advance for any help.
Old May 17, 2005 | 10:22 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Here's a quick way to check. Take your ohm meter and stick it in the plug under the seat. Then compare that reading with your supplied resistor.
There you go.
Old May 18, 2005 | 12:57 AM
pfogle's Avatar
pfogle
You need to find a way to reinstall the sensor on the new seat. It's looking for a range of voltage not just a fixed signal. The way the system works it tells the airbag when and how to deploy. It's in a non-functional mode right now because it can't tell how much weight is in the seat.
Old May 18, 2005 | 06:33 AM
Kenny Bonnell
I was told by Bruno (the manufacurer of the seat) that one of the the resistors I put in line was to fake the seat into thinking someone was there, they probably don't know what they are talking about. I've had problems with them before, but it takes a lot of time and of course my customers NEED their vehicles as most are not able to drive just any vehicle. Thanks to both of you for the responce. This site is great.
magnet1
2004 - 2008 F150
Sep 7, 2010 07:43 PM
Shark Bait
Feb 25, 2010 07:29 PM
brc777
1997 - 2003 F150
Oct 15, 2009 09:46 PM
mfreeoff
Mar 10, 2009 09:31 PM
bill87123
Oct 19, 2005 03:52 PM
