Bronco II Ford Bronco II
Water leak?
Old May 17, 2005 | 06:43 PM
jrongi1's Avatar
jrongi1
Water leak?
My b2 (88 2.9)has sprung a major leak some where at the back of the block.
any ideas what mite be leaking and how to fix it without pulling the motor or trans?
Old May 17, 2005 | 06:51 PM
plilikoi's Avatar
plilikoi
Bummer. It sounds as though you could have blown a head gasket, so long as you're sure it's not the heater core.. The only way to tell is to get in there with good light and a mirror to see where the leak's coming from.
Old May 17, 2005 | 07:39 PM
Ken00's Avatar
Ken00
Are there any freeze plugs back that way, I don't recall for sure.
Old May 17, 2005 | 07:54 PM
jrongi1's Avatar
jrongi1
It is draining out the bellhousing
Old May 18, 2005 | 09:04 AM
orlysan's Avatar
orlysan
If I remember correctly there are some frost plugs on the block inside the bell housing. It could likely be one of those leaking. You would have to pull the tranny and flywheel/flexplate to get at them.
Old May 18, 2005 | 10:29 AM
Monty06's Avatar
Monty06
you have four freeze plugs in the back where the bellhousing resides.
