Aftermarket Electronic Ignition??
Old May 17, 2005 | 05:21 PM
smitty1956's Avatar
smitty1956
What is a good inexpensive aftermarket electronic ignition system to put in a 71 F-250 w/360 engine?
Rich
Old May 17, 2005 | 06:01 PM
fordxxx's Avatar
fordxxx
The Pertronix point replacement kit is very popular. It is simple to install, inexpensive, and reliable.
There is a module that goes where your points are now and an 8 magnet thing that goes over the dist cam.
Once you have the Pertronix unit install you can replace the coil with their high voltage FLAME THROWER coil and then you can open you spark plugs gap up to about .05". It will make a noticable difference to how your truck starts and runs.
Old May 17, 2005 | 07:28 PM
70T351W's Avatar
70T351W
I installed the pertronix system in my 351w and so far it is great!
Old May 17, 2005 | 09:27 PM
Kostiuk's Avatar
Kostiuk
I'll throw my vote out there for the Pertronix also. I've been running it in my 69 w/360 for years with out any problems.
Old May 17, 2005 | 10:59 PM
achtungeveryone's Avatar
achtungeveryone
I have pertronix on another vehicle and can't complain. It is also the least expensive system that I'm aware of. Crane cams makes an optical system that folks like and it is also inexpensive. MSD makes units as well.
Old May 17, 2005 | 11:19 PM
Fomoko1's Avatar
Fomoko1
I was considering using an 76 FE factory electronics but used a Prertronix as it is simpler to hook up.
Old May 18, 2005 | 07:16 AM
oppy's Avatar
oppy
Ditto the Pertronix. Next easiest and cheapest would probably be a Duraspark like Fomoko said.
Old May 18, 2005 | 12:07 PM
smitty1956's Avatar
smitty1956
Does anyone who has installed the Pertronix systems see a big difference immediately? Starting? RPM'S? Idle? Etc...
Rich
Old May 18, 2005 | 02:04 PM
oppy's Avatar
oppy
Yes, I noticed an immediate improvement in starting.
Old May 18, 2005 | 04:32 PM
Kostiuk's Avatar
Kostiuk
Yep, easier starting and smoother idle.
Old May 18, 2005 | 05:56 PM
qman's Avatar
qman
How much does a kit cost?
Old May 18, 2005 | 06:12 PM
smitty1956's Avatar
smitty1956
They are on EBAY I am gonna get one in about 2-3 weeks. Looks really good and the results of what the others say does mean something.
Rich
Old May 18, 2005 | 07:59 PM
chromedaddyo's Avatar
chromedaddyo
Pertronix owners beware, They are my Ignition of chioce, I am happy with the simplicity, BUT!!!
My buddy pulled my pos cable with the engine running,,,,, an old school check of the alternator working, and when he reconnected it with the engine running it spiked the ign unit and smoked it, game over for the ignition. Other than the friend factor I have no complaints or problems with the Pertronix.
dave
Old May 18, 2005 | 08:23 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
There's always some one different, i'll chime in. Cranes XR 3000 with LX-91 packs a good punch, ran Allison for years without and problems, Crame purchased them and called it their XR 700. Optical trigger systems don't get false magnetic signals. This is a inductive system not capacitive discharge.
XR300 can handle higher current coils than XR700, cost a little more than Pertronics.
Carl....=o&o>....
Old May 19, 2005 | 06:42 AM
jowilker's Avatar
jowilker
You can find them for just under a hundred bucks.
John
