Ford in your Ford
Western Nationals June 25th - Grand Prize Drawing - 5.8L/351 crate motor.
Winner not be present - Ford will drop ship to your house.
8.5:1 compression ratio
Ford racing dual plane 4V aluminum intake, Ford Racing tall polished aluminum valve covers, V-belt standard rotation mid 70's style cast iron water pump with left hand inlet, aluminum timing chain cover with fuel pump mount, fuel pump block off and eccentric, E5AE-6090-CA cylinder heads without thermactor air passages, F4TR-6380-AA HD truck manual trans flywheel, high torque flat tappet cam E7JE-6250-AA, full sump oil pan, Duraspark distributor and coil, spark plug wires, block is hydraulic roller cam compatible.
