Sponsored by: Auxito
Inside Temperature
Old May 17, 2005 | 06:51 AM
Vandiyan's Avatar
Vandiyan
Inside Temperature
I am having problems with the inside temp of my 1999 F-150 truck. The problem is the thermostat that you use to dial in whether you want it hot or cold air blowing seems to be stuck on cold right now. When I turn the dial it does not feel like it is grabing anything to actually turn the dial on the inside. My question is, has anyone had this type of problem and is it something that I would be able to fix or would it be better to take it to a dealer and have them fix it? Also would it be expensive at all. My guess would be it should not be too much but hey what do I know.
Old May 17, 2005 | 10:33 AM
jklmvincent's Avatar
jklmvincent
Vandiyan,
Been there, done that. The most likely (and easiest) problem is that the **** has cracked. Pull of the kknob (carefully) and look at the back. There is a slotted key that goes on the end of the shaft. On mine, the keyway had cracked, so that the **** just spun on the shaft without turning it.
Some people replace the ****, others use Crazy Glue, I replaced the ****. I don't remember the price off hand, but it was pretty cheap. The crack was so bad in mine, I didn't think a glue job would hold up.
Old May 17, 2005 | 10:37 AM
Vandiyan's Avatar
Vandiyan
Thank you very much for the advice. I was hoping and thinking that it probably was something pretty easy. What a relief to know that it actually was for a change.
99 F250 SD 4x4
May 19, 2014 07:07 AM
turnkyle
Oct 1, 2013 12:53 AM
joeycyph56
Oct 6, 2010 10:19 AM
Matts66
Jan 25, 2004 11:48 AM
bigvinney
Sep 12, 2001 06:18 PM
