Gear Oil
Old May 17, 2005 | 06:21 AM
Dan Robertson's Avatar
Dan Robertson
Gear Oil
I would like to change the gear oil in the transmission of my 1946 Ford 1 1/2 ton truck. Can anyone tell me how many quarts of 80-90 it holds. Thanks!!!
Old May 18, 2005 | 02:41 PM
46yblock's Avatar
46yblock
Dan, I finally brought in my manual from the barn. If you havent already done the change this is the info I have. The chart is for 1940 trannys, but probably is applicable to yours. All of the four speeds, and some of the heavy duty 3 speeds call for a 5 pint lubricant capacity.
Old May 19, 2005 | 05:43 AM
Dan Robertson
Thanks for the info.
Dan
Old May 19, 2005 | 07:52 PM
howdy71475's Avatar
howdy71475
The research I did said that it too 600W oil in the trans. I don't plan on using it in mine, I figured I would use 150W so as you can shift it in the winter. Hope this helps.
Old May 19, 2005 | 08:13 PM
46yblock's Avatar
46yblock
Oil weight
This manual calls for 90 in the winter and 140 in the summer.
3twinridges
Mar 23, 2015 12:20 PM
51FordTN
May 20, 2013 06:57 PM
95350PS
May 18, 2012 05:57 PM
kystangbanger
Jan 16, 2010 08:48 AM
dgcoonass
Feb 12, 2008 10:53 AM
