Front pinion seal.
Old Mar 1, 2000 | 05:18 PM
67CAT's Avatar
67CAT
Front pinion seal.
Old Mar 25, 2000 | 11:03 AM
Katt's Avatar
Katt
Front pinion seal.
How difficult is it to replace the pinion seal on a dana 44 IFS? Any special tools required? Thanks
Old Mar 25, 2000 | 05:34 PM
PAUL_2's Avatar
PAUL_2
Front pinion seal.
Katt ,
Before you replace the seal check to make sure the vent hose isnt blocked . Have you been running it in 4wd or is it just leaking w/o using it in 4wd ? If you do have to replace the seal , you have to establish the pinion bearing preload before you loosen the nut to remove the yolk . Then its just a matter of prying the old seal out and installing the new one . Its very important you tighten the nut back so the preload on the bearing is the same ...this keeps the pinion and ring gear teeth in the same contact pattern and ensures the bearing isnt too loose or tight .
Paul
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
