1965 Mercury??
Old May 23, 2005 | 05:26 AM
jowilker's Avatar
jowilker
Originally Posted by Haaser
Thanks Guys
Since i've already tore into the mercury quite a bit I will continue with that project first.I have power discs in it and am going to be dropping a 1972 302 with the high compression. Next addition will be power sterring cause I have most of the parts. Since this Merc isn't original how much depreciation have I done by modding. This truck is a loaded custom cab because it has ALL the options.
Adding bolt on creature comforts shouldn't change the price down any. Do it for your self and if someone offers you a gaggle of money for it, put it in your pocket and start on the other truck.
John
Old May 23, 2005 | 05:59 AM
FordBoypete's Avatar
FordBoypete
Haaser,
I agree with John, in that Value is as arbitrary as style and model. Adding upgrades to safety, performance and creature comforts, as well as the appearance should not in any way reduce fair market value. I will add it most likely will increase it.
I'll put qualifying conditions on that. The conditions are: 1 So Long As You Don't Make Permanent Modifications. Meaning cutting and altering things so they are no longer able to return to OEM stock Condition. and 2 as long as you do nice work and don't cobble the Slick when you're retro fitting items to/on it.
Bolting things in place is not permanent alteration, cutting and welding frames and body and so forth is. Permanent alteration may or may not improve the market value, but for sure it will narrow down the potential market, IMHO.
If somebody is in the market for a "Stocker" they probably have no interest in a truck that needs or needed anything done to it. They most often want a clean, mostly original version that's been well kept and maintained, or so I have found. I saw a really pristine version at Carlisle they were asking $15K for . .It didn't sell while I was there.
So my bottom line with me is, it's my truck and I'll do it to suit me. Another thing I always told my clients is don't build it to suit the market, build it to suit yourself, but don't permanently alter or modify it in some custom manner, unless you plan to keep it forever. . . or are prepared to take some loss if you do sell it.
FBp
Old May 23, 2005 | 09:31 AM
Dan White's Avatar
Dan White
The Merc is cool, long bed and all. The step box is only good for target practice, find a field and dropit off, locate a short fleetside.
Old May 23, 2005 | 12:23 PM
FordBoypete
I agree! Chevy Stepsides should be shot, however I don't think its' a very good idea to shoot a Flareside Box. I know more folks that want them than I know folks wanting to destroy them.
As for putting a Fleetside on a Ford product it would really look stupid, short or long!
Use a FoMoCo Styleside instead, eh?
FBp
Old May 23, 2005 | 01:26 PM
Ringo Fonebone's Avatar
Ringo Fonebone
Haaser, you are luck in that you have a Twin I truck, so the changes you make should not be irreversible. Lotsa guys with stockers,even, do the disc conversion for thier own self preservation.
The small block, while I am a great fan of them, is a tougher one for stock guys to choke down, However, with our well over $3 a gallon prices here in the land of milk and oil, I think its not gonna hurt you in resale. FE's are thirsty buggers.
Tastes in trucks are somewhat regional, as you know, flaresides are very common here, where short/wide stylesides are rare. especially before the late seventies in Fords. I would have done the same as you, in fact I did. My longbox Merc is a '64, but I made changes FbP might not approve of to the frame. Best thing is to build it for yourself, so you are happy. With a Merc, shaving embems, etc that give Mercs a distinction, is kind of counterproductive, keep all the Merc stuff on IMO. I even added a bit of imbellishment on mine
https://www.ford-trucks.com/user_gal...=65042&width=0
So, you've made your choice, in time maybe you'll even have 2! Best o' luck!
RF
Old May 24, 2005 | 07:53 AM
FordBoypete
RF,
I have one of those front ends under Mammas 4X4 Aero . . altho' I'm not enraptured with the notion of Ball Joints, It's not so much approval, as a case of laziness on my part. I just find it easier to swap frames. Down here in the land of Beaches & BiKiNis frames are still plentiful & generally in good shape. Ergo the regionality issue again, . .
. . . Doncha see?
As fer retired . . . Ahyup! I am. I'm 19 & I've more than 47yrs experience at being 19. Don't let the name FORDBOY fool ya, it comes from "Bite Me Ford Boy" that many put on their brand X vehicles. My slick is set up so I usually am able to bite them good!
That makes them cranky, but when they discover I'm way older than my slick they get upset. Bad enough losing to a truck but losing badly to an Old Ford Truck driven by an even older guy in it has got to hurt their ego.
FBp
Old May 25, 2005 | 04:53 AM
jowilker's Avatar
jowilker
Yeah, you old farts are real stinkers.
from a modestly mature gent.
John
Old May 25, 2005 | 10:37 AM
Dan White's Avatar
Dan White
Dear Ford Boypete, yeah, you really got me there on the fleetside/ styleside thing! Bad lango on my part.
later
Old May 26, 2005 | 08:08 AM
FordBoypete
Thumbs up Dan White - Welcome to our Slick world, Man
Hey Dan. . . . Welcome to FTE
It's all here Dan.
If it's not here already, just ask & somebody will put it here. Immeasurable wealth of FoMoCo & Ford, F-Series Truck, Specific, knowledge & experience is present among members here. They are THE BEST. No Doubt about it. I appreciate being corrected when I'm wrong. . that's one way I learn more.
As a long time Blue oval affecinado I've taken a load of #*!^%$@ from too many Orange replacement engine people, for too long. I shy away from using anything like brand names, brand style names, and other brand specific stuff they use. FoMoCo "ain't a underling" all those Orange Motor folks convinced themself it is. In fact aside from gross production numbers alone, quite the very opposite, or reverse is actually true.
FoMoCo or MoPaR invent and improve, then Great Myth pretty much copies others' ideas. It's been that way since William Durant started that company nearly 100 years ago. Some accuse Durant of being the P.T. Barnum of U.S. Automobile History. William Durant is said to have forged the terminology,
.... "there's an *** for every seat". Judging by what the company built over the years, I tend to think he really believed himself with that.
Never the less if your interest is 61-66 Ford F Series Trucks, aka FoMoCo Slick 60s Trucks, you're on one of the very best sites around specific to 'em.
So welcome Once more and We'll be looking for you on the boards Dan. Glad to have you along, can always use more good humor in life doncha know?
FBp
Old May 26, 2005 | 08:36 AM
FordBoypete
Wink Ah Er Wait A Moment. . . .
John. . . . Ahem, Sir. . . ., that should read " Real Qwik, Fast, disliked, Stinkers" should it not?ROTFLMAO
I sincerely believe it is an earned position & privilige based on the dues it takes to get here in tact doncha see. . . .
FAST FBp
Old May 26, 2005 | 10:34 AM
Dan White's Avatar
Dan White
Wink
later
Seems I,m having difficulty navigating edit / post options! whatever.
Old May 26, 2005 | 10:49 AM
Dan White's Avatar
Dan White
Smile Politically correct
It's all here Dan.
FBp
Yeah, thanks for the welcome. I find it hard to be politically correct all the time, don't you?
Say, got any channies in that tool box of yours? How 'bout a crescent wrench?
dw
Old May 26, 2005 | 07:00 PM
  #28
FordBoypete
Yeah ! !
I keep water pump pliers right next to my 10" adjustable wrench underneath my (are ya ready) Milwaukee Skill Saw Heh heh heh, How politically correct is that. . .?
Seriously Dan, welcome aboard, b'sides anybody with initials DW has to be Okay!
As for navigating aids & options, on this site after a certain amount of posts life gets easier and ya can also post a lot more too, with more ease etc. etc. Don't worry you'll get the hang of it mostly all of us have. When I 1st started I realized I was an Idiot. I thought I outgrew that forty or fifty years ago, but NOPE! I are still an Idjit (at heart).
CIAO' <O> FBp
Old May 26, 2005 | 09:01 PM
  #29
Dan White's Avatar
Dan White
Cool, alot of people don't have the humor, I see you do
dw
Wilsons654xlb
13
Nov 11, 2014 08:07 AM
dentside250
13
Aug 1, 2011 04:36 PM
429unibody
24
Jul 21, 2011 06:57 AM
supercabfreak
Sep 26, 2010 11:32 PM
zakflynn
15
Nov 20, 2004 07:19 AM
