Head Gasket Being Replaced
Old May 20, 2005 | 11:48 AM
MRKnight's Avatar
MRKnight
Aside from maybe a clogged cooler or excessive RPMs for an extended amount of time does anyone know what could cause the oil temp to raise high above normal? I've actually never heard of that happening.
Old May 21, 2005 | 06:36 PM
npccpartsman's Avatar
npccpartsman
And what kind of oil is being run???
Old May 21, 2005 | 07:47 PM
barkweld's Avatar
barkweld
factory FORD oil
Old May 22, 2005 | 12:23 AM
Brian460's Avatar
Brian460
Excessive or prolonged hot EGT will cause a hot oil condition. Diesels use a lube oil spray to keep the piston temp down.
I was thinking of getting a second X-Monitor for engine oil temp, rear diff temp, and either oil pressure or water temp.
allingeneral
Computer Chips & Tuners
May 5, 2010 12:26 PM
DesertDiesel
May 24, 2006 06:22 AM
Shift_for_Brains
Dec 4, 2005 09:08 PM
TN_Jeeper
Oct 16, 2004 04:40 PM
Ford1TonsRock
May 18, 2004 07:37 PM
