Sponsored by: Auxito
What PSI
Old May 15, 2005 | 08:29 PM
Patatoe1's Avatar
Patatoe1
What PSI
I was wondering what PSI i should have my tires inflated to. I have them now at 30psi all around, and i was wondering if it should be somthing different.
Old May 16, 2005 | 01:15 AM
Racerguy's Avatar
Racerguy
I usually set them at 35 psi unless the truck will be carrying a load.
Old May 16, 2005 | 01:42 AM
maticuno's Avatar
maticuno
I ran 32 in the front and 28 in the back on my Ranger...but my F-150 is much heavier so I just set it today at 42 in the front and 36 in the back.
Old May 16, 2005 | 03:15 PM
furrby's Avatar
furrby
on my 01 f150 it says in the gas door to set them at 35 all the way around. i there an advantage to having the rear with a lower psi?
furrby
Old May 16, 2005 | 03:21 PM
fordman311's Avatar
fordman311
I think the only advantage that would have would be if you didnt haul very often. Or atleast didnt haul heavy stuff. I gotta go fill up but i ususally run about 40 all the way around.
Old May 16, 2005 | 04:02 PM
Patatoe1's Avatar
Patatoe1
Does the higher psi make for a bumpier ride? and would my 30 psi be to low?
Old May 16, 2005 | 04:08 PM
Bruker's Avatar
Bruker
It's been my experience that higher tire pressure will give a bumpier ride, increase tire wear in the center of the tire, give less traction on wet roads and increase mpg.
Old May 16, 2005 | 04:21 PM
99F150's Avatar
99F150
Never set below the tag on the door... Remember all the idiots with Explorers. My 99 4x2 calls for 32 front and 35 rear. Also donot go above max psi on tire sidewall. My tires have a max psi of 35. I keep all four the same at 35 psi and the wear has been even.
Dan
Old May 16, 2005 | 04:28 PM
MrBSS's Avatar
MrBSS
You should run the tires per the pressure listed on the door jamb. If for some reason you don't have it there, get an owner's manual, or go to Ford. It is not possible for anyone to properly make a recommendation without knowing all the details of your truck, it's tires, and the loads it handles.
For example, my F150 recommends only 26 psi in the front tires (factory "Sport" package, 275/60x17), which surprised me and everyone else who sees it. The rears are 32 psi.
We know it is dangerous to run low, but it also can be dangerous to run high: less tread contact and impact resistance.
Old May 16, 2005 | 06:16 PM
fordman311's Avatar
fordman311
Right now my tires are at about 30-32 PSI. I was going to filll em all up to about 40, but from what i hear its good to leave them as ford recommened? I have oversized tires, thats why I though they should be inflated more. Max cold inflation is 65 PSI, 32".
Old May 16, 2005 | 06:40 PM
kingfish51's Avatar
kingfish51
What type of tires are they? Are they P series, LT? If LT, what load range? Also are they original or replacements. If OE are P series and replacements are LT or visa versa, you do not want to go by the sticker. If OE are P series and replacements are LT, the sticker PSI will be too low. Too high if the reverse. The sticker PSI is only good if the tire on the vehicle is the size and type listed. If what is on ther are P series then 32 to 34 would probably be about right. If LT it would depend upon load range. Load range C would probably be about 36-38, maybe 40. I have not had any experience with load range D, but when I had LR E tires, I started at 50 and worked up as needed. This all assumes we are talking about an F150, not a heavier truck.
Old May 16, 2005 | 08:19 PM
1991fseries's Avatar
1991fseries
the PSI listed on the door jamb is only good for factory spec tires anything other type of tire would require a different PSI than that, just remember the rims are rated for 60 PSI so u can't go over that
Old May 17, 2005 | 08:47 PM
MrBSS's Avatar
MrBSS
While the LT tires, and especially C or higher rated tires, can stand higher pressures and consequently greater loads, I don't think that they require higher pressures. I do know that you cannot assume greater load capacity when using them because other components will then become the "weakest link". Consequently, IMHO, they should probably be inflated to about the same pressure as the standard tires (maybe a few PSI higher) and will then have about the standard load capacity.
I guess I'd recommend that anyone contemplating a significant change from the OEM tires should talk to the tire company.
Old May 20, 2005 | 11:04 AM
kingfish51's Avatar
kingfish51
MrBSS, they do require higher minimum pressures. Listed below is the site that has the regulations for the new requirements for tire pressure warning monitors. About 1/4 of the way down the page you will find a table which shows the tire type (load range), maximum tire pressure, and the pressure at which the monitor would activate and give the driver a low pressure message. Load range C warning pressure is 29psi, load range E is 46, with LR D being in between.
Old May 20, 2005 | 05:33 PM
Patatoe1's Avatar
Patatoe1
Where is the link?
