Sponsored by: Auxito
What PSI
Old May 20, 2005 | 05:43 PM
kingfish51's Avatar
kingfish51
Sorry about that.
http://www.nhtsa.dot.gov/cars/rules/...ule.html?name=
Old May 20, 2005 | 08:40 PM
Patatoe1's Avatar
Patatoe1
Thanks for posting the link.
Old May 21, 2005 | 06:10 PM
LxMan1's Avatar
LxMan1
I run mine @35psi per Fords recommendation. It is more stable and gets the best mileage when running what the manufacturer recommends.
Old May 22, 2005 | 10:07 AM
aztec12's Avatar
aztec12
Talking
i have mine at 35 psi all around. i think 35 its like the sweet spot,you can go lower or higher but for the most part 35 is a good #
Old May 22, 2005 | 10:43 AM
bigdaddyII's Avatar
bigdaddyII
I run what the sticker says on the door. 32 in the front and 35 in the rear.
Old May 22, 2005 | 12:16 PM
Patatoe1's Avatar
Patatoe1
Well mine says 29 front 32 rear, but with the 29 in front the tires look like they are going flat.
Old May 23, 2005 | 09:56 AM
MrBSS's Avatar
MrBSS
I believe that the minimum pressures indicated for "extra" load tires are based on each tire's rated load. Since a given tire's load rating is based almost entirely on the pressure which it can accomodate, if an "extra" load tire is loaded only to the "standard" load, it does not require the additional pressure.
I guess I would go a few pounds heavier just to minimize flexing of these heavier wall tires.
