71 429 total timing issues
Ok, I have been trying for months to get this fixed, only problem is no one around here knows how to adjust the vacuum adv timing. I have a 71 ford 429 with dove-c heads, holley 770 truck avenger, edlebrock perf rpm intake, lunati cam etc... I have my base timing at 10 btc and I am getting constant pinging when it gets hot. And it does get hot now over 200. Sometimes it even runs on after I shut it off. The engine is about 10,000 miles just rebuilt about 1 year ago. I use premium fuel every other tank I even use octane booster. I used some sea foam and changed the plugs today also. It is no better. I need to know how do I adjust the vacuum advance timing? I set my base with the vacuum disconnected and plugged. Do I use an allen key and which way do I turn it? How do I vheck the advance timing?
I forgot to mention that the truck has no bottom end power and also has some hesitation. The truck use to hover around 160 all the time before I screwed with the timing,new pulleys and such. The Vacuum advance was disconnected and plugged before I bought the truck. I have since reconnected it.
You need to check total advance without the vacuum connected. If it is higher than 38 degrees (34 is better), you need to back off on you initial timing. Vacuum advance can be checked several ways. The easiest is to run the engine with vacuum connected at 3000 rpms and check the timing and the engine vacuum. Record those numbers. Now disconnect the vacuum and run again at 3000 rpm and check timing again and vacuum. The difference between the timing numbers tells you how much the vacuum is rolling in. But you need to be aware that it can be as much as 10 to 15 degrees over mechanical advance. Prefer using vacuum pump instead of the engine vacuum, but if you don't have one the engine method works. Vacuum advance drops out very fast when you go down on the throttle when the engine is under load as it is a function of engine vacuum..
You have to check the mechanical advance first as it is a function of engine RPM and isn't effected by engine load (vacuum). The total advance is normally concidered to be the mechanical only. Vacuum varies to much.
Ok, I am confused. How do I check the mechanical advance? To check base I just remove the vac line and use my timing light correct? But how about mech adv?
I also have a 460 with DOVE-C heads, and have had pinging problems, and also the engine was lazy. What I did was remove the vacuum advance and just ran the timing up till the engine pinged when in hard acceleration and then backed off some. The engine runs cool and has lots of power. My ignition system is a MSD box and distributor, but this method will work for a factory ignition setup as well. To check mech. advance, run the engine at 4500 rpm's and check timing.
Originally Posted by Bear 45/70
Where is the vacuum advance hose hooked up too, the carb or the manifold?
The carb. I used the one that stated it was for vac advance. it is a holley ta 770 and the port is on the pass side front.
