Starving?
Old May 14, 2005 | 04:45 PM
72earl302's Avatar
72earl302
Exclamation Starving?
I just did a cam swap on my 72 302 and put it back in my truck. It starts and runs great for about 30 seconds and then stalls out, I'm using a comp cams 268H camshaft and an edelbrock 600cfm carburetor, and I switched to an electric fuel pump. The engine sounds like you're trying to pull a trailer up a big hill and then just dies quick. I don't think it's flooding out because it doesn't shoot dark smoke out the exhaust, I think it could be starving out and wonder if the floats in my carburetor could be to blame, it stayed in a box for about a month, but I don't think that should matter that much. Any help with this problem would be greatly appreciated because I am really looking forward to driving my truck.
Old May 15, 2005 | 03:52 PM
fordfan302's Avatar
fordfan302
Have you tried adjusting your idle screw on your carb???
Old May 15, 2005 | 07:54 PM
72earl302's Avatar
72earl302
I haven't adjusted my idle screws, but when I start it I run it at about 2000 rpm. Would the idle screws cause it to just die out of the blue?
Old May 15, 2005 | 09:52 PM
luvinfords's Avatar
luvinfords
Make sure that the fuel pump is doing it's job. Sounds like it is starving for fuel.
Old May 15, 2005 | 11:00 PM
umdstang's Avatar
umdstang
is the electric fuel pump putting out to much fuel pressure, carbs dont like anything above 9 or so psi. i would check the fuel pump and install a pressure regulator if the electrick pump if rated for more than 9 psi
Old May 16, 2005 | 10:53 AM
72earl302's Avatar
72earl302
I just noticed that the alternator light is staying on when it's running would the alternator cause this problem? The fuel pump seems to be working alright and I think it's rated between 5 and 7 psi. I'll try messing the idle screws, and if that don't work I'll recheck all of my wires, then if that don't work i'll try a pressure regulator.
Brandon80
15
Jun 10, 2018 12:41 PM
ufvj217
Jun 1, 2013 03:02 AM
BlackCustom77
13
Oct 28, 2012 09:40 PM
me Mickey C
Feb 4, 2008 12:47 PM
72 Camper Special
Dec 18, 2002 09:02 AM
