My flathead V8
Old May 14, 2005 | 12:36 PM
FordDump's Avatar
FordDump
Question My flathead V8
Can anyone tell me if I can bolt up a newer V8 in place of my flathead V8 to the existing running gear. This 1948 Ford is the bigger dump truck version. Any information will be appreciated.
Thank You,
David from Calif.
Old May 14, 2005 | 02:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 14, 2005 | 06:18 PM
mtflat's Avatar
mtflat
They're compatible, but I don't know of any bolt up deals. Chassis-wise it's pretty simple, but the motor mounts are in the wrong place and bolting your trans to the new engine will need an adapter. Have you considered swapping out your crashbox transmission at the same time. That makes it a lot easier.
Get a tubular engine crossmember and transmission crossmember and bolt it together.
Old May 14, 2005 | 06:48 PM
FordDump's Avatar
FordDump
Will this effect the pump for the dump? It runs off my clutch.
Old May 14, 2005 | 06:56 PM
barry's Avatar
barry
I've seen a few swaps, but with "Y" block motors. That seemed to be the hot setup at the time. I think anything newer would require a engine-tranny out of a later truck and some fabrication of mounts, driveshaft, etc....
Barry
50 F-1
