Dana 50 disassembly help
Old May 14, 2005 | 09:35 AM
gavin's Avatar
gavin
I've got a 1980 F250 4x4 with a Dana 50 front-end. The front's got a pretty bad leak somewhere around the differential. Since the designer was bright enough to not put a diff cover on this assembly (sheer genius, I tell ya), it looks like I have to tear the whole thing apart just to replace the gasket.
My Chilton's wasn't terribly helpful regarding disassembly - I'm concerned since the case extends all the way to the knuckles, etc.. So, assuming I just remove the 10-ish bolts around the front of the diff, will the front case then swing away? Is any part of the assembly under tension from the suspension - do I need to jack the truck up so that the axle is unsprung, etc? I can't really tell just from looking at it?
Thanks.
Old May 14, 2005 | 02:44 PM
seizure911's Avatar
seizure911
dana 50 disassembly
I am no mechanic, but I just pulled out my entire axle assembly. You will have to support your truck by the leaf springs or frame to unweight the axles/arms.
I didn't have any tension on mine, other than the weight of the thing.
I pulled the left drive axle out of the carrier (punkin) after removing the automatic hubs. I seperated the right drive axle at the slip yoke, removed the front driveshaft and then unbolted the carrier (the 10 bolts and 2 larger ones on the left side). I was able to worm the carrier out of the "arm"/housing". I didn't see how I was going to be able to put it back in ( without smearing the form a gasket all over) later without pulling the "arms" out so I remove the pivot bushing bolts and the leaf spring u bolts and pulled the arms. I am going to assemble the arm and carrier and then install it as a unit.
While I had everything torn apart, I am doing the carrier left and right axle seals, as well as replacing the spindle hub seals and spindle hub dust seals, and installing a new (longer) breather tube. I also am replacing the drive axle u-joints, just so I don't have to do it later.
I have found most of the seals at Napa, they also have the clamps for the boot on the right drive axle.
1993 f250 diesel
Good luck.
Johno.h
Nov 12, 2016 04:18 AM
rat_6
Feb 3, 2016 03:55 PM
Diesel_Brad
1983 - 2012 Ranger & B-Series
Nov 18, 2015 07:04 PM
sunuvabug
Jan 5, 2015 04:55 PM
DuallyBoy
Offroad & 4x4
Dec 2, 2002 01:54 PM
